any one has 18x8 setup?
would I have problem if i get a wheels with 18x8 setup on both front n rear? Thinking about getting HP Evo wheels but I can't find 18x8 & 18x8.5 or 18x9 combo. Only 18x8.5 I found was chrome and i'm not really into chrome wheels. I guess they don't make 18x8.5. Thanks in advance!
04c, Black, AT, PIAA, AL padel, smoked clear corner, 6th grounded-wire, z-tube/pop-charger, UR pully, Data grille & Gialla spoiler, 15% tint
Re: any one has 18x8 setup?
Define "problem". The only thing I could see why they wouldn't fit would be offset issues. If you are looking for a specific manufacturer, I would recommend contacting them (or a large retail seller of their product) to see if you can get the model, finsh, size and offset you are looking for.
Guest
Posts: n/a
G35 Coupes with sport option and 6-MTs have 18x8.0" wheels all the way around. The stock wheels have a 30 mm offset. The stock tires are 225/45 in front and 245/45 in rear. If you are going to get new tires, get 245/40 in front and 245/45 in the rear for better balance.
04' G35 Coupe 6-sp
Diamond Graphite/Willow w/Premium
04' G35 Coupe 6-sp
I agree with Loren. 245/40s are much much easier to find than 225/45s, and will reduce some of the understeer built into the car. You could even put 255/45/18s in back. However, offset is a major issue. On the coupe you really don't want less than +30mm (same as stock).
Lou
Lou
I sell a lot of HP EVO's in 18' and I do have 18x8's and 18x9's 5x114.3 offset with 38mm offset. Let me know if I can help: www.HenrikGal@aol.com
Here are some pictures if anyone else is interested: http://www.cardomain.com/memberpage/342829/5
