HELP!!! 20" wheels makes the steering wheel shake.
Old Jul 12, 2009 | 05:49 PM
G.St@'s Avatar
i just got 20" msr staggered wheels and when i hit the highway going around 60-80 my steering wheels shakes....its really annoying. can anybody help with what i need to do.
Old Jul 12, 2009 | 06:11 PM
05G356MT's Avatar
did you make sure the lugnuts are torqued to spec? also you after putting on lug nuts, you're supposed to re torque after 100 miles. its happend to two people i know.
Old Jul 12, 2009 | 06:23 PM
Invalid_User's Avatar
Has it been balanced correctly ?
Wheel bent?
Old Jul 12, 2009 | 07:02 PM
skyline250GT's Avatar
Have they installed locating rings?
Old Jul 12, 2009 | 07:20 PM
bigc's Avatar
Wings Nation
sounds like you need hubcentric rings
Old Jul 12, 2009 | 08:34 PM
EL-EE-ES's Avatar
+1 on hubcentric rings
Old Jul 12, 2009 | 09:33 PM
G.St@'s Avatar
well i just put the wheels on today but i will def. get my wheels rebalanced. also.. where do i get these hub rings at?
Old Jul 12, 2009 | 09:46 PM
bigc's Avatar
Wings Nation
some wheel shops and most tuner shops will have hubcentric rings. you can also buy them from the vendors in the marketplace.
Old Jul 12, 2009 | 10:27 PM
D&G35's Avatar
^^^just be sure to buy the right size rings...and if u need spacers, sum of them come w/ hub rings too..g/l man and be careful driving
Old Jul 12, 2009 | 10:49 PM
Gu3s5who's Avatar
Had that problem when i first got wheels for my old car. Good luck man...
Old Jul 12, 2009 | 11:09 PM
Gr8speed68's Avatar
Did u get wheel alignment..
Old Jul 13, 2009 | 12:14 AM
G.St@'s Avatar
no i didnt think it was neccessary. but i will look in to it. thanks for all the help
Old Jul 13, 2009 | 12:32 AM
Gr8speed68's Avatar
YVW
Old Jul 13, 2009 | 11:29 AM
cato's Avatar
SouthernComfort Moderator
Some jerks installed my hubcentic rings on backward and the car was undrivable at 20 mph. I had to turn around and have them re mount the wheels. So if you need hubcentric rings, you should notice it at all speeds, not just above 60 mph. Sounds like a wheel balance issue.
Old Jul 13, 2009 | 01:52 PM
bigc's Avatar
Wings Nation
^ Geez man, sounds like you had a bad wheel guy. I don't even think you can get a wheel to sit flush to the hub if your hubcentric rings are backwards!
Anyway, you'll notice vibration at all speeds, however, its MUCH more noticeable after you get above 50mph. Moreover, if the OP isn't running hubcentric rings then he needs to do it anyway.
