Will.i.rub.ADVICE.pls.
Old Aug 12, 2009 | 04:09 PM
LR-G's Avatar
Exclamation Will.i.rub.ADVICE.pls.
Hello,
Summary:
I finally found my TENZOs TYPE M 19x8.5 and 19x10 in the rear.
I am lowered enough just above the rear tire and front tire.
Maybe a tad more in the front.
With 275/40/19 in the rear will I RUB?
With 245/40/19 in the front will I RUB?
VERY ADVANCE THANKS.
Old Aug 12, 2009 | 04:14 PM
redlude97's Avatar
with those huge tire sizes? Probably. Why would you run something that large? The correct sizes are 245/35/19 and 275/35/19
Old Aug 12, 2009 | 04:17 PM
LR-G's Avatar
i severely needed rear tires but i did not have the rims. and i wasnt sure if i was going to get them at all.
should I raise the rear or both for now?
Old Aug 12, 2009 | 06:46 PM
redlude97's Avatar
that doesn't explain why you bought the wrong tire sizes....
Old Aug 12, 2009 | 08:32 PM
jdmgee35's Avatar
+1 wrong tire sizes. Get 35 series tires instead and u won't have problems. GL.
Old Aug 13, 2009 | 01:09 AM
Skaterbasist's Avatar
Retired SuperMod
Tire sizes are off. Too tall.
We also need to know the offsets of the wheel. Unless you are running very aggressive offsets, you shouldn't rub. But then again... you have the wrong tires to begin with.
Old Aug 13, 2009 | 01:30 AM
LR-G's Avatar
+17 in the front
+22 in the rear
Old Aug 13, 2009 | 01:31 AM
da mayor's Avatar
what springs are you lowered on?
Old Aug 13, 2009 | 09:49 AM
LR-G's Avatar
BC RAcing Coilovers
