18" 9.5 +15 wheels
18" 9.5 +15 wheels
Hi from Australia guys, sorry don't have time to search.
Can anyone tell if these wheels will fit all round and look ok. I know most people run staggered offsets, but am not sure why since the stock wheels are not staggered offset. This way I will have big fat dish front AND back, which I love the look of.
Will these rub at all front or back with my G coupe lowered 1.5"? I have no camber kits at this stage fyi, so have no option to tuck the tops in, and will be regularly rotating tyres to avoid inner tyre wear.
Should I go 18" x 10 +15 at the rear, or will that be too much and cause rubbing?
I am not too keen of rolling or flaring my guards.
Thanks for any advice!
yes i have the exact same wheel setup, 18x9.5 +15 all around. i have about 4 degrees of camber in the rear, and about 3 degrees of camber in the front. to make the tire sit flush i would need about a 20mm spacer in the rear and 15mm in the front.
good luck
good luck
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
