Questions about wheels and Offsets for Sedan
Old Sep 6, 2009 | 12:19 PM
gtrefever's Avatar
if you want to run spacers on coupe 19s id run a 10mm spacer all around thats if u want to keep the stock tire sizes on them
Old Sep 8, 2009 | 03:38 PM
ttrank's Avatar
Grocery getter
The coupe 19's fit quite well without spacers.
Old Sep 8, 2009 | 06:34 PM
4DGS's Avatar
Ok, I've found some wheels I like for a relatively likable price! No I'm not telling you what they are.
They are 19x8.5 and 19x9.5, the dealers said they sit flush so I am unsure of the exact offsets.
What size tires should I run for this set up?
Old Sep 8, 2009 | 09:58 PM
eurodre's Avatar
the dealer said they sit flush.. lol thats a funny one, thats what a vendor told me when i was ordering my wheels.. he was going to suggest to me a +20 offset... i wanted -8
but why not a bigger width? maybe 9/10?
Old Sep 8, 2009 | 10:13 PM
CandlestickPark's Avatar
ill Sedan
Here is my setup just for reference. I was going to an aggressive setup without super stretched tires. Its kinda in between, not fat tires and not skinny tires either.
Like others have said, roll your fenders very flat. Also consider your ride height and camber settings.
Wheel/tire specs:
Front
19 x 8.5 +15 (10mm spacer)
20.4 lbs
Toyo Proxes T1R 245/35/19
Rear
19 x 9.5 +20 (10mm spacer)
20.7 lbs
Nitto Invo 255/35/19
Camber set a -2.75 all around.
Front fitment:
Rear Fitment:
Old Sep 9, 2009 | 02:25 AM
4DGS's Avatar
Just curious what vendor was that?
Marcus, I hate you so much. Every time I see your car I realize how many things I need to do to mine!
Are those offsets including the spacer? or are those the factory offsets?
Old Sep 9, 2009 | 03:02 AM
eurodre's Avatar
i won't say what vendor, but pretty soon I will because they are pissing me off, my wheels are mega delayed
but lesson is, dont listen to what the vendor sais about what is flush, 9/10 they don't know what flush is
but take marcus' advice, his sedan is ON POINT
Old Sep 9, 2009 | 10:06 AM
FlyingLumpia's Avatar
Just in case you missed the specs that was mixed in the pics. Here
Wheel/tire specs:
Front
20.4 lbs
Rear
20.7 lbs
Old Sep 9, 2009 | 10:07 AM
btw did a toe and rear camber. All my camber is in spec and no rubbing. Of course I could lower it more now.
Old Sep 9, 2009 | 10:55 AM
4DGS's Avatar
Ok I have the offsets now.
+35 front and +40 rear
How close to flush is that? And if I run them like that(no spacers) am I going to need a camber kit? Could I just slap the wheels on and drive them with out it burning through tires?
I was trying to avoid buying a camber kit, but if I have to I guess I have to.
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
reaper76
Aug 5, 2015 10:13 AM
Soumilg
Jul 18, 2015 12:33 PM
