Those looking for replacement Brembo rotors
Old Aug 7, 2004 | 06:29 PM
ZUL8R's Avatar
I think I found a pretty good deal for us. Nopi.com has genuine Brembo x-drilled OR slotted rotors for $275 per front pair and $273 for a rear pair. They also have a 4 wheel SS brakeline kit for $108. I just ordered everything and it came out to about $700 shipped. What do you guys think, everywhere else I saw the rotors for $400+ per pair. They are out of rear drilled rotors right now but expect some in in a couple of weeks. They do have rear slotted in stock. It took 3 days to get my fronts and line kit. Just wanted to let you guys know about a god deal.
Old Aug 8, 2004 | 03:13 AM
6mtInCharlotte's Avatar
Re: Those looking for replacement Brembo rotors
That's a pretty good deal. I'm in the market myself and was going to go with Tirerack.com for the x-drilled set, but NOPI's are definitly cheaper. Thanks.
Old Aug 9, 2004 | 01:42 PM
roadracer's Avatar
Be careful, I do not think these are actual Brembo rotors?
It is well known that companies brand them as Brembo and they are not! Check out these Brembo rotors, they are the same part number as Brembo's and have a different drill pattern.
Part#
# FD00097
Product Name: Brake Rotors
Manufacturer: Brembo
Make-Model: Infiniti - G35
Year: 2004 - 2003
Weight: 45.00 lbs.
List Price: $ 439.00
Our Price: $ 335.99
Description: Front (Pair) - Brembo Sport CROSS-DRILLED Brake Rotors
2003+ Infiniti G35 w/ 6 Speed Manual Transmission
Click here for more info on this Product
Here is the link to these rotors:
http://www.importrp.com/catalogm.php...year_name=2003
Just an FYI!
'03 G Coupe, 6 speed, Bose, Nav, Pearl White, Black leather, 350Z airbox, more MODS to come!
Old Aug 9, 2004 | 01:43 PM
roadracer's Avatar
here is the pic:
Old Aug 9, 2004 | 01:48 PM
roadracer's Avatar
Dunno know why that did not work?
Old Aug 9, 2004 | 01:49 PM
roadracer's Avatar
last try........if it is not there, you can see the pic if you use the link!
Old Aug 9, 2004 | 04:22 PM
ZUL8R's Avatar
Here's what mine look like
Old Aug 9, 2004 | 04:24 PM
ZUL8R's Avatar
They also have the brembo logo stamped on the rotor by the stud hole you can see it in the pic.
Old Aug 9, 2004 | 05:04 PM
G352NV's Avatar
Never enough
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Aug 9, 2004 | 05:27 PM
roadracer's Avatar
Those look nice! Brembo logo on them? I think I will order a set, thanks!
Old Aug 9, 2004 | 08:35 PM
ZUL8R's Avatar
If you look @ the left rotor you can see the Brembo stamp. It is just to the left of the top stud hole.
Old Aug 9, 2004 | 08:48 PM
roadracer's Avatar
What pads are you going to run? Same front and back? Thanks
Old Aug 10, 2004 | 11:23 AM
ZUL8R's Avatar
Probably Hawk HPS's I have the HP+'s now and they stop very well. The HPS's are suppose to create less dust though.
Old Aug 12, 2004 | 11:14 AM
dieu's Avatar
Interesting. The Brembo slotted rotors featured at Importrp.com, are slotted in the opposite direction as the Brembo slotted rotors featured at tirerack.com
Take a look:
http://www.tirerack.com/images/brake...rt_slotted.jpg
http://www.importrp.com/images/bremb...ss-drilled.jpg
I have a problem with this because I doubt Brembo would make two different slotted rotors for same car. That is, slots running in different directions. Not knowing more about these rotors, I believe someone is selling rotors branded as Brembo. If push comes to shove, Tirerack.com has way more credibility.
jsimonk
Dec 22, 2023 03:49 PM
Frankieg35
Mar 20, 2016 09:42 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
RedBaronK
Jul 27, 2015 03:19 PM
vstypicals
Jul 20, 2015 10:55 PM
