abnormal treadwear solution?
Old Sep 25, 2009 | 03:35 PM
money042's Avatar
i recently purchased a set of 350Z 18's for my winter setup. They came with Dunlop Winter Sport M3s. Good tread left, however, on closer examination, the tread is more worn on the inside. My question is, should I have the tires flipped around on the rim so that the inside is on the outside, and vice versa? Will that help with the future tread wear? I currently have factory suspension.
Thanks
Old Sep 25, 2009 | 03:44 PM
JIle342's Avatar
Flip 'em!
Old Sep 27, 2009 | 03:01 PM
Q45tech's Avatar
Differential side to side wear is caused by excess negative camber. Tires are designed for +- 0.5 degrees max camber but to enhance handling more negative camber is used.
Remember alignment is actually misalignment, [sitting still] numbers created by factory to be roughly correct driving straight down road at 55 mph.
Old Sep 27, 2009 | 09:11 PM
money042's Avatar
Thanks for the feedback... so, should I flip them?
Old Sep 28, 2009 | 05:21 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
If you have adequate tread depth left go ahead and have them mounted on the other side. Just make sure they are rotating fwd and not backwards.
Old Sep 28, 2009 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
Thanks
You mean putting the tires on the right on the left and vice versa, yes, that would really help with the treadwear. You can do this because your tread is symmetrical. But it's also directional so make sure they are still rolling forward as said. Don't flip them on the same rim as then they would be rotating backwards.
Old Sep 30, 2009 | 12:14 PM
Q45tech's Avatar
Don't assume that directionality means much after a directional tire is worn even half way by 8,000 miles it is pretty meaningless for water evacuation.
The noise tuning is also gone so the noise increases significantly as the tread depth changes.
Members should consider less aggressive camber levels with winter tires as they are less like to drive frisky anyway, to prolong life of winter tires.
Tires function best for durability and treadwear when camber is -0.5>0>+0.5 degrees.
Old Sep 30, 2009 | 03:08 PM
money042's Avatar
cool, thanks all. I think I got it. I'll need to take both tires off the wheel, trade sides and then flip them. And, as some of you mentioned, the tires are directional so this should make them roll the right way. Thanks, again.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
TurTLe*
Sep 29, 2015 01:43 PM
brycealbr
Aug 11, 2015 11:47 AM
