Tires on right side show more wear than left? Wierd!
Old Oct 7, 2009 | 08:34 PM
bruuster's Avatar
I have a 2007 g35 sedan. I'm getting towards the end of my tire life with 36,000 mile on the OEM Goodyear RS-A. I've got about 3-4K miles left on the tread. I drive in a mostly dry climate here in L.A.
Strangely, when looking at the tires, the right front and back have the same amount of wear but are more worn overall than the left side. The wear is even so I don't think it's alignment. I don't have anyone or thing heavy that travels in the right side of the car. How can this happen?
I rotate the tires only front to back.
Thanks,
Bruce
Old Oct 7, 2009 | 10:08 PM
cryhavok's Avatar
Interesting that you post this. My rear tires are getting close to replacement and the right rear one has less tread thickness than the left...weird.
Old Oct 8, 2009 | 12:56 PM
Q45tech's Avatar
When you accelerate the weight shifts to the right side. Do you turn right more than left? All it takes is 5-10% more right turns.
When you get alignments every 6 months do you check the calibration of the machine/rack.
Common when rear thrust angle is off even 0.02 degrees. The problem is static [sitting still]alignment with worn suspension bushings is somewhat worthless considering how the system behaves at 60 mph.
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
wonderizm
Sep 24, 2015 03:09 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
rping
Jul 26, 2015 09:53 PM
