Mixing Summer and All-Season tires
Old Nov 6, 2009 | 10:10 PM
bocatrip's Avatar
Mixing different brands are usually acceptable, while mixing summer and all season changes the gripping characteristics and can be dangerous.
Old Nov 7, 2009 | 04:35 PM
Q45tech's Avatar
Always put the best [Michelin] on the rear at least you won't have to worry about sudden power on wet oversteer. Weaker and less gripy [in cold] on front will just increase understeer.
Old Apr 23, 2012 | 03:36 PM
addision's Avatar
Using different tread patterns on front and back shouldn't be an issue. Even among the same tire pattern you will have different grip characteristics when turning as the rear are a different size and different camber. Even among some tire models sometimes you will have different tire tread patterns from one year to the next. So if you bought a tire last year, it may not have the identical tread pattern this year.
The real concern would be having two different tread patterns at the same axle (as reference). That would make thing more hairy and would really mess up the tires.
Old Apr 24, 2012 | 02:31 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
The difference in compound, design, how the operate at different ambient temps, internal construction, etc etc makes mixing those a really bad idea. You can read more about that here,
Mixing Tires
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Phenomenon9
Aug 9, 2015 01:34 AM
bjo16
Aug 4, 2015 09:52 AM
