Tire PSI Thread
Old Nov 3, 2009 | 05:51 PM
thescreensavers's Avatar
Mr.202?
Tire PSI Thread
So what are you guys inflating your tires at for normal use?
Some argue you should inflate to sidewall PSI, but just want to see what you guys think
Front - 32
Rear - 35
I don't really know why I have the rears higher lol. Should be the opposite?
I don't use sidewall PSI for the rears becuse of the loss of traction.
What experiences do you guys have?
Old Nov 3, 2009 | 05:58 PM
nghiars's Avatar
im usually around 33-35 F and 32-34 R depending on seasons
Old Nov 3, 2009 | 06:02 PM
GEE35FX's Avatar
I have NEVER heard of anyone using sidewall pressure, except when they did not know any better.
I usually run 1 or 2 lbs higher than the pressure specified on your vehicles door post.
I run 34 psi right now in my FX and that is also what I ran in my G35 sedans.
Old Nov 3, 2009 | 07:02 PM
marcinr's Avatar
20 Year Member
It depends on conditions, tires, and temperature. Generally in my sedan, I go 32 psi in all four wheels cold temperature, and that's just fine for daily driving with my Yokohama S-Drives. Before, I used Goodyear Eagle F1 GS-D3 and those were better around 34 psi.
So, how do you determine the "correct" temperature? I drive my other car quite a bit at the track, so tire pressure is very important. The best pressure for maximum grip is the one which utilizes the largest portion of the tire's surface, meaning that it's not overinflated and not underinflated. The only way to tell for sure is to measure the tire's temperature with a pyrometer in three places; the two edges and the middle.
You want the temperature gradient across the tire to be linear. You can never have the same temperature in all three measurement spots because of toe, camber, etc, but if you plot the three temperatures on a piece of graph paper, you want them to make a straight line when you connect them. If the three points make a V, you're overinflated since the middle is generating more heat than it should. If the shape is a ^, you are under inflated since the edges are heating up too much relative to the center and the tire is cupping.
Is this overkill for a street car? Yup
Old Nov 3, 2009 | 07:09 PM
JOKER's Avatar
CLUB MODERATOR
37 all around and I'm getting very even wear on all 4 tires even tho I'm dropped.
tragedycat's Avatar
I do 35psi all around, haven't run into any problems.
Old Nov 3, 2009 | 07:34 PM
klee's Avatar
35 all around for me too
Old Nov 3, 2009 | 07:35 PM
HenryLee's Avatar
35-40 PSI for me.
Old Nov 3, 2009 | 07:37 PM
ttrank's Avatar
Grocery getter
NT05's ~35psi front and rear.
Old Nov 3, 2009 | 10:51 PM
eurodre's Avatar
45 because im stretching tires
Old Nov 7, 2009 | 04:39 PM
Q45tech's Avatar
Most tires now are load rated at 51 psi so 78-80% of max 40-41 psi is ideal unless you brake a lot.
Aslways calculate the weight on tires underdiffering handling situations.
Set the psi to create the size of the contact patch [in square inches] you wish.
Old Nov 9, 2009 | 05:35 PM
Mustang5L5's Avatar
That's just the MAX inflation pressure.
What pressure to inflate your car's tires is written on a sticker usually in the door jamb of every car.
Only people i know that inflate their tires to the number on the actual tire just don't know any better.
WHat pressure to use depends on MANY factors, and there isn't one pressure for each car and tire. Factors are weight of car, weight on the wheel, and contact patch area.
Personally, i've actually painted a line across the tire and inspected the wear pattern as the paint wears away. Wear in the middle first and the ttire is overinflated. Wear on the sides first and it's underinflated.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
derres
Aug 28, 2015 03:27 PM
BlackGee35
Jul 31, 2015 11:04 AM
joedaddy1
Jul 28, 2015 02:58 PM
