What size nut on bleeder valve?
Old Aug 23, 2004 | 01:59 PM
townsley's Avatar
Last weekend I bled my non-Brembo brake lines. The bleeder valves on the front brakes were 10mm and I had a wrench for those. However, the bleeder valves on the rear brakes looked to be about half that size and I had to punt to find a pair of mini vice grips to finish the job. I'd like to get the proper size and do the job right next time...
Does anybody know the actual size of the bleeder valve nut on the rear non-Brembo brakes?
-townsley-
03 Premium BS/Willow 5ATS
ZTube/K&N Drop-in/Sport Suspension
Grounded/Tinted/Splash Guards
Lip spoiler/Aluminum Pedals
Old Aug 24, 2004 | 10:26 AM
3point5SE_Auto's Avatar
Re: What size nut on bleeder valve?
8mm
yes it is small
make sure you use a box end or a tubing wrench not a standard open end. you will strip it if you do.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
