CHoosing Tires
Old Nov 27, 2009 | 04:32 PM
cpugangster24's Avatar
CHoosing Tires
I got a 04 Sedan sand the ride is a lil harsh. Need to buy new tires for it and was thinking about changing the size and see if that will help even if just a little bit. Was thinking about using a 215/60/17 size, I know it is going to change my odometer so when it says 60mph Im really goen 60.9mph. Is that the only major issue I'LL see or is there more that will be effected. Really appreciate the advice.
Old Nov 28, 2009 | 01:39 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
The 60 series is a bit taller than normal for the car. Could run into rubbing issues. There's a bit better touring based tire selection in 225/55-17. That should help a bit. Won't really get a large noticeable difference w/out moving into a 16" tire/wheel combo. Less wheel and more sidewall will help out in cushion.
Old Nov 28, 2009 | 04:13 PM
nghiars's Avatar
17's shouldnt really be harsh(this is subjective) if you get good tires.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
