Wider Tires On OEM Coupe 18s
Old Dec 2, 2009 | 04:43 PM
EvanP246's Avatar
Hey guys, Today I put on some 235/35/18 up front and 255/35/18 in the rear. Needless to say my VDC went crazy so I have to swap them out for something else on top of that the wheels look extra small.
Do I have to go back to stock sizes or can i run a slightly wider tire? I just went F/I so wider would be better.
Say 235/40/18 and 255/40/18? I'm pretty clueless on what the VDC requires to be happy.
Thanks
Old Dec 2, 2009 | 07:23 PM
nghiars's Avatar
id run 245/40/18 since they 1.01% bigger than OEM 225/45/18(~1/4 inch bigger). 235/40/18 is smaller by 2.23%(~almost 1/2 in smaller).
and the rears you're looking at is good.
Old Dec 2, 2009 | 10:55 PM
EvanP246's Avatar
Thanks so much man, how do you do those calculations? It would be pretty helpful in future.
Old Dec 3, 2009 | 07:08 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Have had many use 245/40-18F 245/45-18R, but not much more you can do with the oe 8" wide wheel that has the correct overall diameter.
Old Dec 7, 2009 | 07:14 PM
saoLin413's Avatar
you could use this to calculate.
http://www.miata.net/garage/tirecalc.html
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
mushu
Jul 15, 2015 03:55 PM
