Nismo S tune Suspension.
Old Aug 24, 2004 | 12:52 AM
roneski's Avatar
Devil's Advocate
Anyone know anything about these? I just saw them for the first time.
http://www.performancenissanparts.co...oducts_id=1390
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Y pipe...
Old Aug 24, 2004 | 10:15 PM
biscotti's Avatar
Re: Nismo S tune Suspension.
I don't think this set-up is height adjustable and defiitely is not cheap. I would look at HKS or Cusco, very high quality coilovers and adjustable. I've read mixed reviews on the Nismo from MY350Z.com. The one person who wasn't pleased noted that the Nismo felt no different than stock suspension on the Z.
Old Aug 25, 2004 | 07:39 PM
Built2Shred's Avatar
I just ordered it. Been looking for a complete kit for my G35 Sedan and when i read your link, i was stoked. I dont like just using lowering springs, as that will throw off your suspension setup, as the stock shocks were not designed to work with those springs. Finding a setup thats designed for your car and keeps a nice ride is perfect, plus lowers 1.1". I'll let you know what I think after I get it installed.
As far as the guys on 350z goes, the stock suspension is hard to beat unless you want a extreamly stiff ride. With the G35 sedan the ride is to soft even with the optional sport suspension. So I think you will noticed a bigger difference with this setup on the G35 vs the 350z.
2003.5 G35 Sedan White/6MT - 2004 350z Roadster Black/6MT
Old Aug 26, 2004 | 03:18 PM
Gsedan35's Avatar
That is NOT a Nismo sedan setup. That is the G coupe Nismo that of course happen's to bolt right up to the sedan. It does NOT only lower the sedan 1.1 inch, you will in fact lower you around 1.6: to 1.8". The actual sedan Nismo is not imported into the US by anyone, which is a good thing because is use's spring rates that are just a fractional bit firmer then oem. We already have one member running that suspension on his sedan. The thing that must be realized is that the setup is ment to improve the Z, but Nissan's choice of progressive springs on what is intended as more sporting offering is a backwards move, though the spring rate logic used is spot on. Their are better choices to be had to improve the sedan for the same money, frankly for what it offers, it is terribly overpriced for what you get, not to mention better offerings at the same or lower price point.
Their is no such thing as a Z33 or V35 coilover suspension system that can throw off your sedan's suspension. However buyer beware on spring rates and roll stiffness tranfer to the front, like Cusco and G35 HKS LS+ and LS.
All FM platform suspensions are easy to beat, Z33, V35 and CVP35 suspensions squek buy with barely enough work on their shock valving, that is where all after market systems will offer a improvment first and foremost. You do not have to have a stiff ride to have a better suspension on the sedan or coupe for that matter. For instance sedan owners can move to Koni shocks or Tokico D-spec shocks without changing ride quality very much at all and the valving performance in the Koni's is superior to oem. Koni specifically removed compression dampning on the shocks to improve ride quality. Also when you study aftermarket G35 sedan springs you will see that they are not offered with a stiffness that the oem shocks cannot deal with, offten times they are in fact softer then oem.
Oem springs
Front:314 Rear:342
Eibach's as noted (first number is the softer initial rate, followed by the higher final rate)
350Z 296/384 front 316/421 rear
G35c 229/337 front 274/463 rear
G35s 259/334 front 359/413 rear
RSR 350Z springs (just a wee bit progressive F&R, maybe one coil is progressive)
345/417 F+10% R+22%
Transfers +12% roll stiffness to rear
RSR G35 coupe springs (progressive front and rear)
315/315 F+0 R-8%
Transfers +8% roll stiffness to front
Hotchkis 350Z springs (linear springs)
340/330 F+8% R-3%
Transfers +12% roll stiffness to front
Tein S-tech 350z (fronts are progressive, rears are linear)
386/402 F+23% R+16%
Transfers +7% roll stiffness to front
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
Tanabe GF210 Series 350Z
336/375 F+7% R+10%
Transfers +3% roll stiffness to rear
Tanabe NF210 Series 350Z
314/353 F+0 R+3%
Tanabe NF210 Springs G35 COUPE
297/336 F-5% R-2%
Tanabe DF210 Springs G35 COUPE
308/353 F-2% R+3%
Transfers +5% roll stiffness to front
Tanabe NF210 Springs G35 SEDAN
297/269 F-5% R-21%
Transfers 17% roll stiffness to front
Tanabe DF210 Springs G35 SEDAN
286/280 F-9% R-18%
Transfers +9 roll stiffness to rear
Kg/mm springs 350Z
DR21 super sport 15mm drop
246/398 front 252/409 rear
Kg/mm springs 350Z
DRacing 30mm drop
252/454 front 252/482 rear
Espelir coupe springs (the U.S. importer recently changed specs, I do not believe the newly listed specs are correct, since the new one's are extreamly high. And when I called the company to ask if the springs are linear or progressive, they told me Linear, turn's out they were absolutley wrong, they are in fact progressive. I show the old specs for those reasons, take it with a grain of salt, same thing for the 350Z fitment)
409/460F F+30% R+37%
Transfers +7% roll stiffness to rear
Espelir 350Z springs
381/460 F+22% R+37%
Transfers +15% roll stiffness to rear
Tein Flex
672/672 F+114% R+98
Transfers +16% roll stiffness to front
Tein Flex JDM specs (can be special ordered est 6-8 weeks delivery)
560/560 F+78% R+64%
Transfers 14% roll stiffness to front
Tein Basic
504/504 F+61% R+43%
Transfers +18% roll stiffness to front
Tein CS (Monotube)
392/392 F+25% R15%
Transfers +10% roll stiffness to front
Nismo S-tune (uses progressive springs, especially in rear)
448/504 F+43% R+48%
Transfers +5% roll stiffness to rear
Buddy Club Racing Spec coilover (Monotube)
748/280*
(very likely run's rear springs on the dampner body and not at the oem rear spring location)
Jic Flta-2 350Z fitment (Monotube)
560/672 F+78% R+98%
Transfers +20% roll stiffness to rear
Jic Flta-2 G35 coupe (Monotube)
560/560 F+78% R+64% $1750
Jic Flta-2 G35 sedan (Monotube)
504/392 F+61% R+15%
Transfers +46% roll stiffness to front
Cusco Zero 1&2
560/392 F+78% R+15%
Transfers +63% roll stiffness to front (no they do not run their rear springs on the dampner body, oem location, seen them on the car with my own eyes.)
HKS LS+ (rear springs are progressive)
496/440 +58%front +29%rear
transfers 29% roll stiffness to the front
HKS LS G35
448/336 43%front -1%
transfers 44% roll stiffness to the front
HKS LS 350z
448/448 43%front +31%
transfers 12% roll stiffness to the front
HKS II 504/504 +61%front +47%rear $1600
transfers 14% roll stiffness to the front
KW coilovers Variant's 1,2&3
Variant 3's are noteworthy as the only known coilover for these cars where the dampners are adjustable for compression and rebound independently. They also differ in using progressive springs front and rear
Front: 485lbs to 525Lbs Rear: 240Lbs to 548Lbs
D2 Racing Coilovers (Monotube)
840/728 F+168% R+113% (wee bit stiff eh, the recommended rate to)
Transfers 55% roll stiffness to front
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Aug 26, 2004 | 04:29 PM
Ok now you got me worried. On there web page says the Nismo Type S Suspension lowers the coupe 20 mm and the sedan 30mm which is 1.18".. and your saying its 1.6" to 1.8" ????
Are they just lying on there web page or are you just quoting numbers that you really dont have any evidence (on this kit anyways). I need to know because if it lowers it more then the 1.18" then I defeinatly dont want it. I just got a email today saying its on backorder and they will get it in about 2 days. So if what your saying is true, i need to cancel the order.
Also you say this suspension is the same one they use on the Z? how come the Z verion of this supsensin is a lot less if its the same as the sedan/coupe?
Here's the description on the suspension from performance nissans web page
Application: 2003-2004 G35 Coupe or Sedan
Lowers vehicle by 20mm Coupe / 30mm Sedan
Spring rate and damping force tuned specifically for this model 8kg Front / 9kg Rear
Provides improved steering response
Precise bolt-on installation
Reduces body lean, pitch, and dive
Provides neutral, balanced handling
So if all there doing is using the same 350z suspenion and calling it a G35 one and charging more, i'm definatly going to cancel my order
Old Aug 26, 2004 | 04:50 PM
Thanks for the heads up, I just called performance nissan and they confired what you said about the suspension, its designed for the 350z and the installer there said it does drop it around 1.6".... Ticks me off that there web page makes it sound like a specific kit for the G35 sedan and only a 1.18" drop. Talk about being misleading...
Thanks again ..
Old Aug 26, 2004 | 05:03 PM
Never ends.. hehe Ok i just call back from Performance Nissan and the manager told me the kit the installer was talking about was the Type S for the 350z, which bolts on the Sedan and lowers the sedan around 1.8"... He said the kit I ordered is brand new and is a different part number from the 350z and gureantees me that it was designed specificaly for the G35 Sedan and Coupe and will only drop it 1.18"
So what do you think?
Old Aug 26, 2004 | 09:05 PM
jran76's Avatar
I have the Nismo S-tune (350Z) suspension on my sedan. First, let me say it makes quite a bit of difference on the Z. It makes a world of difference on the G sedan.
While the kit is not perfect (errr.... no kit is), I really like it. It is overpriced though. I already had the kit on my Z, so it cost me nothing to put it on the sedan. I originally bought it when the Z came out and it was the only suspension available (I had to order it from Japan).
It does drop the sedan in the 1.5" range, maybe slightly more. Ride quality is not bad, body roll is greatly improved. With the suspension (w/ sways) and Z-rated tires, I was able to take my "test" corner at about 88mph vs. 72mph on stock suspension and tires.
2004 6MT Sedan-- Diamond Graphite
Stoptech 13" Brake kit-- Nismo S-tune Suspension
2003 Nissan 350Z--SOLD
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
