50psi!
Old Dec 5, 2009 | 10:14 AM
psedog's Avatar
Back in SD**
50psi!
I've always kept my wheels at between 32~35 psi. I picked up my car from the shop with my new wheels on and they were at 50psi. I deflated them to 35~36psi.
I now have 20x10.5 @275/30 and 20x9.0 @245/35. I don't know if that would be a reason why they would put so much pressure into the tire. Anyone know if their is a good reason to put so much pressure into the tires?
Old Dec 5, 2009 | 10:34 AM
str8dum1's Avatar
well low profile tires are rated for 50+psi. just check the sidewall.
I always drive with the max inflation values. you gain a good bit of gas milage
Old Dec 5, 2009 | 11:22 AM
willthethrill's Avatar
i keep my 20"s at 45 psi and my oem 18"s at 35
Old Dec 5, 2009 | 11:58 AM
eurodre's Avatar
no way should the psi be at 50 COLD< imagine what its at when it gets warmed up
stick to your original psi
i have my 9.5 on 225/35 and 10.5 245/35 on 45 psi and thats because of the obvious, they are stretched
Old Dec 5, 2009 | 01:20 PM
Calvin's Avatar
Overglorified Altima
My tires are all 35 series and I keep them at 36 cold.
Old Dec 5, 2009 | 01:28 PM
Texasscout's Avatar
Why were they at 50 psi? I'll tell you, it's because they didn't check them AFTER they inflated them to seat the bead. It has happened to me many times. I check my air pressure right out in the tire shop's parking lot, I want them to know I don't trust them and it's usually with good reason.
Old Dec 5, 2009 | 01:38 PM
nghiars's Avatar
i keep my fronts at about 37 and 35 rearin the colder season( Ha like we really have that in so cali) and then 36 and 34 respectively during summer months. When your tires rotate, they heat up and PSI will increase along with it. Plan for that!
Old Dec 5, 2009 | 01:40 PM
psedog's Avatar
Back in SD**
Thank you everyone for your comments.
Texas you brought up a good point that makes sense to me. I didn't think it was good to be at 50psi.
Old Dec 5, 2009 | 02:01 PM
GT-ER's Avatar
I WISH I could keep my tire pressure at 40+psi...my teeth would fall out. Roads down here are FAR too screwed up to run that kinda of pressure. I run mine at 30-32psi because it's where it's mostly bearable yet not too under inflated to cause problems.
Old Dec 5, 2009 | 06:48 PM
Blue Dream's Avatar
I drove ttrank's car solo
S b f!!!
Old Dec 5, 2009 | 10:45 PM
GT-ER's Avatar
S b f!!!
Wha?
Old Dec 5, 2009 | 10:59 PM
Blue Dream's Avatar
She Beast Foo......
Old Dec 5, 2009 | 11:14 PM
GT-ER's Avatar
She Beast Foo......
WTF?
Old Dec 5, 2009 | 11:41 PM
Dubi2087's Avatar
I work a wheel and tire shop and with me it all depends on the size of the tire, the make of the tires, the driving conditions that the tires will be put through, the roads, and overall the car. A performance car I normally put in between 30 to 36 in the front and 36 to 42 in the rear. If the tires are stretched I put between 40 and 45. YOU NEVER WANT TO MAX OUT A TIRE.
Old Dec 6, 2009 | 02:00 AM
psedog's Avatar
Back in SD**
The rears are stretched. 275 on a 10.5" rim. I'll bring the pressure up to 42psi or so. Thank you Dubi. Obviously I don't want to max out my tires. Also, I don't want to risk screwing up my rims by having to low of a pressure and hitting a pothole. Obviously pot holes are detrimental but I'd like to minimize the risk
