questions on a winter set wheels/tires
Old Dec 21, 2009 | 06:17 PM
colsoh's Avatar
I am looking for a winter set for my AT G35 Coupe. My car doesn't have Brembo brake and currently running on stock 18" wheels. I found a set 16" Blizzak 205/20/16 on steel wheels which came off a G35. Will this setup works for my car? Thanks in advance for any inputs.
Old Dec 21, 2009 | 06:44 PM
a1exder's Avatar
hmm those are really small might screw with the ecu
I would say look for 17s
Old Dec 21, 2009 | 06:59 PM
colsoh's Avatar
Ok, Thanks for your input
Old Dec 21, 2009 | 10:58 PM
money042's Avatar
uh... something wrong there. The tire size you listed is a spare tire or something. That's way off. If you ran all 4 at that size, you'd have other issues than just the snow to worry about
Use this:
http://www.1010tires.com/TireSizeCalculator.asp
Plug in your stock tires size on top and the proposed tire size(s) at the bottom. Anything greater than 3% is no good.
Good luck.
Old Dec 21, 2009 | 11:04 PM
lost hybrid RF's Avatar
yeah, definitely get at least 17".
Old Dec 21, 2009 | 11:38 PM
EndlessWaltz112's Avatar
You can't fit 16s. Anything 17s and up will work. Just get some decent 17s with dedicated winter tires and you should be good.
Old Dec 22, 2009 | 12:01 PM
colsoh's Avatar
Use this:
Good luck.
Helpful information. Thanks.
Old Dec 30, 2009 | 12:40 AM
JAE.G35's Avatar
Iam running 215/60/17 on steel wheels with np what so ever.I live in Regina Sk Canada and we have alot of snow and ice on the roads and the car drives just fine (just the the VDC on)
Old Dec 30, 2009 | 07:23 PM
ballain's Avatar
Well i have a set of Toyo Garits Kx on mine,
Got 225/50/17 and 235/50/17 in the back
overall they are really good, altaugh a lil on the pricey side, but less expensive then sliding all over the place :P
Old Dec 30, 2009 | 09:28 PM
spipasput's Avatar
I accept with information: The tire size you listed is a spare tire or something. That's way off. If you ran all 4 at that size, you'd have other issues than just the snow to worry about.
_______________________
website promotion|video submission
Old Jan 6, 2010 | 09:30 AM
colsoh's Avatar
I found another set which come off of a G35 sedan. The tire size is 215/55/17. Will these tires fit my car (G35 coupe, currently on 18" staggered, no brembo brake)?These were used for two winter. What do you think would be the reasonable offer for this set? Thanks,
Old Jan 6, 2010 | 09:32 AM
colsoh's Avatar
I forgot to mention, this set comes with rims and tires. what is the reasonable offer?
Old Jan 6, 2010 | 07:36 PM
money042's Avatar
The sedan's offset is not right for the coupe. Also, "two winters" doesn't help much. You should get the exact or close to the exact mileage. After a certian mileage, winter tires significatly lose they effectiveness.
If you want to expand your search, the wheel off the 350Z match up with the G35 coupe perfectly.
Old Jan 7, 2010 | 10:42 AM
colsoh's Avatar
Thanks for the information
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
multimut
Canada
Jul 26, 2015 08:43 PM
mushu
Jul 15, 2015 03:55 PM
