35 offset
Old Dec 26, 2009 | 02:46 PM
kennymo's Avatar
35 offset
looking to put 20x8.5 and 20x10 both with a 35 offset on my 04 sedan. is thaat going to be pushed out of the fenders or sucked in quite a bit? i did search. couldnt find a straight forward answer. and i will be lowered roughly 1-2 inches
Old Dec 26, 2009 | 02:49 PM
elayman's Avatar
I believe it should sit sorta flush.. you can buy my sevas and they will fit flush on your sedan same sizes but +25 offsets
Old Dec 26, 2009 | 02:54 PM
kennymo's Avatar
how will both a 25 and 35 sit flush. wont the 35 be tucked in by 10mm compared to the 25 offset that you have? can you post a picture of how your sevas sit on a sedan please.
Old Dec 26, 2009 | 02:55 PM
elayman's Avatar
I think these are the same offsets as mine, they are pretty flush
Old Dec 26, 2009 | 02:57 PM
kennymo's Avatar
so then a 35 will sit tucked in a little?
Old Dec 26, 2009 | 02:59 PM
elayman's Avatar
^ I believe so
Old Dec 27, 2009 | 02:04 AM
FlyingLumpia's Avatar
The only way he is going to get that to fit is to roll his fenders flat and a slight pull and most likely have to stretch a 255 or 245 on the rear.
Old Dec 27, 2009 | 02:36 AM
kennymo's Avatar
how will a 35 need to be stretched that much? it should sit in farther than a 25 offset
Old Dec 27, 2009 | 08:42 PM
No a +35 will sit in more "tucked" then a +25
Old Dec 27, 2009 | 09:11 PM
SDGenius's Avatar
it all depends on ur drop
Old Dec 27, 2009 | 09:47 PM
kennymo's Avatar
yea thats what i meant by sit in farther. so what will i need on a 20x10? a 42-45?
Old Dec 28, 2009 | 01:37 AM
That will sit in even further. The lower the number the more it come closer to the fender.
Old Dec 28, 2009 | 01:40 AM
kennymo's Avatar
well i would rather it sit inside the fender a little than be outside the fender a little
Old Dec 28, 2009 | 01:46 AM
hawaiinpunch's Avatar
tuck ftl jk jk
youll be alrite man!
Old Dec 28, 2009 | 01:50 AM
kennymo's Avatar
id just rather run a really meaty tire in the back with a little bulge than have a stretched tire
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
