help need please urgent
Old Dec 30, 2009 | 01:39 PM
itsmerahls's Avatar
my setup is a 05 6mt g35 dropped with tien s-techs tire profiles are 225/40 in the front and 245/40 in the rear with 19"acr rims the trouble im having is that the inside part of the tires in the front are scraping and tore the tires so now both sides are flat in the rear only a little bit not as bad but i dont know what to do or how to fix this do i need spacers? if i do what size do you think i need?
thanks guys i apprieciate any feedback
Old Dec 30, 2009 | 02:22 PM
LightsOut's Avatar
SIETESG
do you have a front camber kit? think your problem is your wheels are so tucked like this / \ that its rubbing the inside.
if its scraping that bad and you dont want a camber kit, then yes, spacers will help push the tire out. Only thing is you will have camber and toe issues and wear out your tire really fast.
Old Dec 30, 2009 | 04:02 PM
itsmerahls's Avatar
where can i get a front camber kit and if i didnt want one what size of spacers you think would help for the rear and front
Old Dec 30, 2009 | 04:07 PM
nghiars's Avatar
What are the specs on your ACR wheels.. diameter, width, offset?
Old Dec 30, 2009 | 04:44 PM
LightsOut's Avatar
SIETESG
camber kits and spacer can be purchased in the Vendor Market Place section or private sales.
do some research prior to purchases
Old Dec 30, 2009 | 07:35 PM
itsmerahls's Avatar
the rims are 19x9.5 rear and 19x8.5 front
350GT-DOT
Accessories
Jun 6, 2010 03:28 AM
HITMANVQ35
Intake & Exhaust
Apr 6, 2010 10:21 AM
kennymo
Dec 2, 2009 01:37 PM
