20" Work VS-XX
Old Dec 30, 2009 | 09:09 PM
grouchandeligh's Avatar
20" Work VS-XX
So will I be able to fit the 20's without having any rub? Could anyone also recommend an offset that would give the largest deep dish look without needing to roll the fenders? I do not plan on going BBK later if that helps.
THANK YOU IN ADVANCE!!
-Wes
Old Dec 30, 2009 | 09:44 PM
Frankieg35's Avatar
Definitly gonna need to get odisk front and rear.. A conservative offset would be +15 front and +23 rear.. U could prolly go a little more aggressive, in sure sone others will chime in..
Old Dec 30, 2009 | 10:27 PM
awesome thank you for the info Frankie. Was hoping something in the 20's would work out. thanks again
Old Dec 30, 2009 | 11:11 PM
Frankieg35's Avatar
Tire size is also important.. If you do 9.5 front and 10.5 rear u can run 245/30/20 and 275/30/20.. Or u can do 255/30/20 and 285/30/20.. Either one would work it's up to u what u wanna run but just make sure they are 30 series or u will rub.. I would do the 245/275..
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
