Tire Question
Old Mar 10, 2010 | 12:28 PM
LordFappington's Avatar
Yeah that should work, you can always refer to the sticker on the driver side door sill. It will have OEM specs on their, I dont know what they are off the top of my head but as long as its close to that you can do it all day long.
Old Mar 10, 2010 | 12:31 PM
Doruk's Avatar
OEM Specs are 225-40-19 F AND 245-40-19R
do you think i am close enough?
i am hoping vdc will not have problem and i guess speedo will be slightly off but not so much?
Old Mar 10, 2010 | 01:20 PM
nghiars's Avatar
you'll be fine^^^
http://1010tires.com/TireSizeCalculator.asp
^^^use that site to caculate the differences in rolling diameter. It will tell you how much the speedo will be off as well.
Old Mar 10, 2010 | 01:27 PM
Doruk's Avatar
should i check for front tires here? i mean where does the speedo calculates the speed from? front tires i guess?
Originally Posted by nghiars
you'll be fine^^^
Old Mar 10, 2010 | 02:06 PM
nghiars's Avatar
^^^yes... how the calculator works is you must enter your OEM tire size first and then you can enter other sizes you're considering. Submit it and the site will find the specs for rolling diameter and will also tell you what % the size is off by and how that will affect your speedometer.
Old Mar 10, 2010 | 03:43 PM
jardoeli's Avatar
Since your from Canada I suggest you go here:
https://www.tiresavings.com/tireShop...season=Regular
I just ordered 2 SPTs and saved $100 so if you order 4 you will save at least $200!
Canadian pricing for tires is a ripoff.....
Especially when they don't adjust price for US exchange. $1 CAN is almost on par with $US, so these companies are making a killing on canadian clients. Bunch of F*ckers.
Shipped to me in Montreal in 4 days!
This what they say on their website:
Why is there such a large difference between the U.S. and Canadian price on the same item?
This is not a simple matter of currency exchange. All Canadian destined orders are shipped from our Vancouver based warehouse and sourced out, in most part, from Canadian distributors. Some items we sell in the U.S. are sourced out from our U.S. affiliates who ship them directly to our US customers. There is a difference, and quite often, very significant, between the dealer cost prices in US and Canada. Let us assure you that we work very hard to bring you the best prices possible, always.
at $100 more PER TIRE, I'm sure they are working "really" hard....
Old Mar 10, 2010 | 05:48 PM
Abdizzle's Avatar
Originally Posted by gary c
You should have no problems running the 245/40F and 255/40R. I've never understood why Nissan likes to put those smaller tires on the front anyway except for less rolling resistance and better gas mileage? Who cares about that?
Gary
They do this as a safety buffer to promote understeer and prevent people from losing the rear end. With less grip available on those 2 tires the front end washes out (understeer) before the rear loses grip which is easy to correct (lift off) unlike an over steer situation where steering/throttle input and a experienced driver are required.
This is common practice amongst all companies that produce RWD cars. They are designed to understeer at the limit so grandma doesn't crash, the only cars that are neutral/oversteer off the dealership lot are pure sports cars/exotics and AP1 S2000's LOL.
Old Mar 10, 2010 | 08:17 PM
Dr. Jekyl's Avatar
As with my C6 Z06, from the factory I have 325's in the rear and 275's in the front.
Old Mar 11, 2010 | 04:00 PM
stbeeman's Avatar
Does anyone have empirical experience (i.e. track-time) with reducing push via tire size on the front? It makes sense, but I would worry a bit about turn in and steering effort.
Old Mar 11, 2010 | 04:13 PM
LightsOut's Avatar
SIETESG
Originally Posted by Doruk
Hello everyone, I have searched but couldn't find my answer.
I am getting 4 new summer tires for oem 19s.
i wanted to go slightly wider for the tires since they were the same prices with oem sizes.
is it okay if i go with
245-40-19 for fronts
255-40-19 for rears
I have notices people suggested 245-35-19 for the front but i don't want to go with thinner tires since i don't like rougher ride.
BTW i have 05 coupe 6mt and its stock height.
also the best price tires i found here in Ottawa/Canada is KUMHO SPTs.
Can anyone give me their review about these tires if they tried them.
thank you
honestly if your worried about rough ride, then get some 18's.
going with 245/35 you wont even notice the ride difference.
245/35
255/40
are the sizes you should go with.
Old Mar 12, 2010 | 02:28 PM
Doruk's Avatar
thanks for the recommendation but i don't wanna go down to 18s
i though it would be much difference if it is not noticeable then i would try this setup. another question with this setup is does wider fronts makes the turns harder or something? i mean any over all disadvantages of this set up?
thanks
245/35
255/40
Old Mar 12, 2010 | 02:41 PM
LightsOut's Avatar
SIETESG
thanks
wider tires will have more traction to the ground, as for cornering it will be the same. Add some sways and cornering will improve much more.
Old Mar 12, 2010 | 02:58 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
tirerack.com for me, I shipped it close to the border and picked em' up on a trip down to the states....i'm now sorta regretting not getting 255's in the rear.
Old Oct 19, 2010 | 07:26 PM
G35er06's Avatar
Finally i have decided to go with
235-40-19F
255-40-19R
and with kumho spt tires
stock height no spacers oem wheels
any comments? suggestions? do you guys think that it is a good set up?
Where you actually able to find 235/40/19 F with the Kumho's
Did you purchase the set locally, because that size doesn't show as available.
Old Oct 23, 2010 | 02:28 PM
  #30
Doruk's Avatar
I didnt but 235s i got 240s for front
