20" Axis Pentas
Old Mar 17, 2010 | 11:12 AM
Stidrver's Avatar
The wheels are EXE konvex and the weigh around 30lbs each if i were you i would go with a 35 series tire with 275's in the rear and 245's up front and get a set of 350z h-techs that to me is the closest to stock ride your going to get. My friend has an 04 coupe running this setup and it rides very nice.
Old Mar 17, 2010 | 11:37 AM
iamtexasmade's Avatar
that sick. def like it. Im going to get the same setup. i thought spec says to get 30 series?
Old Mar 17, 2010 | 11:40 AM
Stidrver's Avatar
I have a 30 series tire on my set up but if you want it alittle quieter go with a higher sidewall.
Old Mar 17, 2010 | 11:42 AM
perfect...i just want to make sure my speedometer is straight with the 35 series tires. thanks a lot man!
Old Mar 17, 2010 | 11:46 AM
Stidrver's Avatar
You may have to run a 30 series tire on the 20x10's I belive thats the size my friend runs he has 35 series in the front and 30's in the rear.
Old Mar 17, 2010 | 11:50 AM
oh lets do it. getting the rims tomorrow ftw
Old Mar 17, 2010 | 11:58 AM
Stidrver's Avatar
Good luck to you enjoy!!
Old Mar 22, 2010 | 01:55 AM
STIDriver quick question. I read the post from you and your friend without even thinking that I talk to you on the forum. Listen I am a everyday driver like your friend. I either want to get the Tein 350z H-tec springs like his or the Eibach Springs like yours. I def like your drop better being that everyone I hear that has the h-tec have to do the spring mount mod to get it within the drop I want. So considering that I don't want coil overs, camber kits, uneven tire wear, or anything else..... just a simple spring and alightments....which ones should i get?
Old Mar 22, 2010 | 07:54 AM
veenie123's Avatar
Originally Posted by Stidrver
Im running 20in wheels on my ride with 255/30's up front with 285/30's in the rear and lowered with eibach pro kit and the ride is great you will hear and feel more of the road but not too bad. I lost alittle accelleration going to 20's but i did add a 5/16 motordyne plenum spacer, stillen z tube,and topspeed pro 1 exhaust and picked up my lost acceleration real quick i absolutly love my G coupe now. heres a pic for you.
Love the wheels, white coupes are pure sex.
Old Mar 22, 2010 | 07:24 PM
Blue Dream's Avatar
I drove ttrank's car solo
not big on adding a spacer tho
If you want to increase your car's performance this is a big mistake. One of, if not the, best bang for the buck mods you can get. Easy to install yourself too.
Old Mar 23, 2010 | 07:55 AM
Stidrver's Avatar
The h-techs drop in the front are perfect but the rear only drops a half inch if you want more you have to do the spring mount mod. As far as the pro kit it dropped my car a little over an inch all the way around and i love it all i did was put in rear spc toe bolts and alignment and they got me pretty close to spec my tire wear is un noticable so far with 2k of driving on them.
Old Mar 29, 2010 | 06:40 AM
njestes's Avatar
Im riding with 20's on my G. I just put them on not too long ago. It doesn't ride that bad at all vs 18's. I lowered my ride with tein H tech spring. Perfect drop for 20's and no wheel rub. Im riding with 245/35 in front and 285/30 in the rear and they look awesome. 275 will be fine too. I wouldn't be worried about the spedo change. It shouldn't be major if at all.
Nick
Old Apr 2, 2010 | 12:25 AM
Stidrver....so far so good. got the axis pentas on....getting a drop on h techs Saturday...
Old Apr 2, 2010 | 12:42 AM
Stidrver's Avatar
Look's great!!
Old Apr 5, 2010 | 01:24 AM
  #30
alow's Avatar
G looks awesome! I plan to get the same setup as you... What size tires did you go with?
