PLease explain the offset
Old Mar 15, 2010 | 10:50 AM
SILVERAZG35's Avatar
I am buying 18X8 rims and I want 235/45/18 on all 4 tires.....will these work in the front and not stick out past the fender?? I know that the offset has something to do with this, but what offset will keep me within the fenders? Most of the wheels that I have been looking at are +35 to +45 offset. Will the +35 tuck under better or will the +45 tuck under better? Thanks for your help
Old Mar 15, 2010 | 10:56 AM
Swivel's Avatar
Moderator
Here's a pretty good explanation of offsets.
http://og-made.com/archives/2174
You should be able to compare your new wheel widths/offsets to your stock widths/offsets (you will have to search those up) and come up with a pretty good idea how new wheels will look.
Old Mar 15, 2010 | 11:14 AM
str3zz's Avatar
Do 245/40/18 on all 4 it will work just fine. Mine is 245/35/19 and still behind front fender
Old Mar 15, 2010 | 11:17 AM
Swivel's Avatar
Moderator
^^ What are your offsets? Tire size is not the only factor.
Old Mar 15, 2010 | 12:48 PM
Thanks swivelhips!
Old Mar 15, 2010 | 12:56 PM
Swivel's Avatar
Moderator
No charge. Hope it helps.
Also look through the stacks of wheel threads, and maybe post what wheels you're looking at, maybe somebody else is running them. OEM or aftermarket?
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
