Tire and Speedo question
Old Mar 15, 2010 | 03:10 PM
4DGS's Avatar
Ok, so I am about to mount and run 19" wheels. 9.5" rear 8" front.
I have 2 rear tires, 275/35 that I boought from stclair who pulled them off the wheels he just bought. He also has the front tires of said wheels that are 245/35. The guy who owned the wheels before him knew his **** and is extremely car oriented.
My question is, can I run these and not have any problems?
the diameters are;
245/35
Overall Diameter: 25.75 in 654.05 mm
275/35
Overall Diameter: 26.57 in 674.87 mm
which gives me about a 3% difference, which will make my car run 3% slower on the speedometer right? So when I'm going 100kms, I'm really be going 96.
Is this really a problem, does anyone drive like this?
Old Mar 15, 2010 | 03:18 PM
Jeff92se's Avatar
Red Card Crew
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/55-17 4.7in 13.2in 26.3in 82.7in 767 0.0%
275/35-19 3.8in 13.3in 26.6in 83.5in 759 1.0%
245/35-19 3.4in 12.9in 25.8in 80.9in 783 -2.1%
Old Mar 15, 2010 | 06:22 PM
4DGS's Avatar
I know how all the sizing works. I just need to know if anyone is running out of proportion tires problem free.
Old Mar 15, 2010 | 06:27 PM
Jeff92se's Avatar
Red Card Crew
3% diff inbetween the fronts/back isn't going to be a problem. But you were referring to the speedo so I thought it was the rear dia that you had an issue with
Old Mar 15, 2010 | 06:31 PM
4DGS's Avatar
Well yea, I'm not too worried about the speedometer being off by 3 or 4kms. I just want to know if there is any issues I might run into?
I plan to go through the rear tires experimenting with my drop and then replace them with 275/30 instead to even it out.
Old Mar 15, 2010 | 06:36 PM
Swivel's Avatar
Moderator
3% faster isn't it? Same revolutions, more distance covered. Reading 100, doing 103. Except you should be comparing to the stock size, not the front size, so really only 1% as Jeff's post pointed out.
No big deal. Except if you were actually talking about swimwear. Then no.
Old Mar 15, 2010 | 06:38 PM
Jeff92se's Avatar
Red Card Crew
This is what I run:
225/40-19 3.5in 13.0in 26.1in 82.0in 773 0.0%
255/35-19 3.5in 13.0in 26.0in 81.8in 775 -0.2%
This is what you want to run:
245/35-19 3.4in 12.9in 25.8in 80.9in 783 0.0%
275/35-19 3.8in 13.3in 26.6in 83.5in 759 3.2%
Although your sizes have a bigger difference, I'd say you're within acceptable limits. I remember the general limit being 5% or something
Old Mar 15, 2010 | 06:39 PM
nghiars's Avatar
you'll be fine. I had 245/35/19 and 275/35/19 when I ran my volks but now im running stocks with 245/40/19(even bigger).
Old Mar 15, 2010 | 06:42 PM
Swivel's Avatar
Moderator
I ran 235/35 front and 245/40 rear for most of last summer, probably an even bigger difference (just over 3%). No problem other than my fronts looked too much like rubber bands, LOL!
I'll be running 245/35 and 255/35 soon (1% difference)
Old Mar 15, 2010 | 06:44 PM
4DGS's Avatar
Alright sounds good.
I figured it would be alright since the original owner of Jamal's Volks ran these sizes.
Nghiars; I haven't decided if I'll go with a larger profile tire or smaller next. I usually don't like rubber band tires so I'll probably go up to a 40 SW.
Thanks guys.
Old Mar 15, 2010 | 06:53 PM
STCLAIRWEST's Avatar
Add spacers and stretch that biatch
Old Mar 15, 2010 | 06:56 PM
4DGS's Avatar
For sure adding spacers, stretch might come later lol
Old Mar 16, 2010 | 05:46 AM
jin22gt's Avatar
Wow. Didn't know wider tires would change the diameter. I only throught it was the profile that changed the diameter.
I gotta get tires for my new rims coming (axis pentas). I've got 19x8.5 front and 19x9.5 rear.
What is the proper tire width range for 8.5 and 9.5?
I was thinking of getting 235-35 front and 265-35 rear. How's this setup?
Also why do people get higher profile up front or rear?
What tire size do u guys recommend? I've got awd.
Thanks
Old Mar 17, 2010 | 02:10 PM
thescreensavers's Avatar
Mr.202?
Well the sidewall number is just a ratio to tread width right?
So running a wider tire will change the spedo if you run the same sidewall number on the wider tire.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
