What would be the best wheel setup out of these choices?
Old Mar 28, 2010 | 11:47 AM
Stackz_on_Deck's Avatar
Well summer is coming and Stackz is getting ready to shut the streets down once again and buy some new rims for the g35 coupe. I'm trying to achieve an almost flushed look if not even sticking out a few mm is OK!
22x8.5 +15mm
22x8.5 +30mm
22x9.5 +15mm
22x9.5 +30mm
That's it... just give me your opinion on the best wheel setup from the above choices to go all the way around.
BTW: im just looking for the right answer as far as fitment.. i dont care if you like 22's or not, if u dont believe they belong on a g35, if ur 19" racing rims are way better, or anything like that. thanks
Old Mar 28, 2010 | 12:30 PM
vq35dedriver's Avatar
22x9.5 +15 with a 15mm spacer on all 4 corners
Old Mar 28, 2010 | 03:54 PM
biggz786786's Avatar
okokok, all jokes aside
it depends on your offset....to give you an idea im running 20x9.5 front with +25 offset and 20x10.5 with +30 offset in the rear, i just added 15mm spacers on all 4, and now my rear RIM sticks out just a BIT from the fender and my front RIM is flushed with my front fender
so with the spacers i am now at +10 offset in front and +15 in the rear
if you can give us an offset then we can better help you
Old Mar 28, 2010 | 03:59 PM
LiquidREVUP's Avatar
like biggz said, offset is definitely key info here... find out what offset the rims you are getting and post it up
Old Mar 29, 2010 | 12:08 PM
Correct me if I'm wrong but didn't I post it in the OP?
The rim comes in two widths... 8.5 and 9.5. And each width comes in two different offsets... either +15 or +30.
Old Mar 29, 2010 | 02:06 PM
oh sounded like you meant 15mm or 30mm spacers...
Old Mar 30, 2010 | 01:49 PM
So nobody? I'm planning to buy in the next couple of days then I will post pics after I get them on...
Old Mar 31, 2010 | 10:23 PM
Armin'sG's Avatar
ur going to want to do 22x9.5 +15 with 10 or 15mm spacers.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
Gomer
17 Inch
Aug 13, 2015 08:53 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
