Wheel Offset Fitment question
Old Apr 1, 2010 | 05:31 PM
RelliKg35's Avatar
Hey guys i just got an 05 coupe and i picked up some 20x8.5 +35mm and 20x10 +43mm MRR gt1 wheels. Im getting my fenders rolled tommorow but my question is will these wheels work? do i need spacers for them to be a little more flush? What size? im going to drop the car with the tanabe df210 springs so i dont want any rubbing. And for the rear tire size do i want to go 275/30 or 275/35? Thanks in advance
Old Apr 1, 2010 | 05:53 PM
Borna's Avatar
To be honest with you, I'd say sell the MRR's and get another set of wheels. Those widths and offsets aren't even aggressive on a sedan, let alone a coupe.
If you can't sell them and go for wheels with more aggressive offsets, then I'd say go for 25mm spacer front/rear.
You want to go for 275/30 for the rear tires.
Old Apr 1, 2010 | 10:19 PM
RelliKg35's Avatar
Thanks for the prompt reply...with those offsets are the wheels going to be tucking under the fender?
Old Apr 2, 2010 | 12:54 AM
jookyshank's Avatar
I haz hugz to givez
As Borna said, those offsets are pretty passive (see aggressive ) You would need spacers to flush em up for sure
Old Apr 2, 2010 | 10:49 AM
Borna's Avatar
Yeah they'll tuck quite a bit after you drop the car.
You can always get the spacers like I said but if you are able to sell them and get a new set it would be even better. You'll get more lip out of it on wider wheels.
Old Apr 2, 2010 | 11:21 AM
RelliKg35's Avatar
thanks for the help guys! Much appreciatted. Im ordering spacers now 25mm for the front and rear should make them flush?
Old Apr 2, 2010 | 12:05 PM
str8dum1's Avatar
at least 30mm spacers for the rear
Old Apr 2, 2010 | 01:14 PM
Borna's Avatar
Yeah the 25mm should do the job. As str8dum1 said, you could go for 30mm in the rear but it would make the rear a little more aggressive than the front. (You could go for 30mm front and back to make it even more flush)
Just make sure you get no less than 25mm all around and you'll be fine.
Old Apr 2, 2010 | 01:17 PM
nghiars's Avatar
25 F and R would be good. You would be pretty flushed.
Old Apr 2, 2010 | 01:35 PM
biggz786786's Avatar
just remember get some very good set of spacers if you plan to run 25mm or more, i would settle for ichiba v2 at minimum, also, going with 25mm spacers or higher will always cause more problems down the road compared to 15mm spacers, in fact slapping on spacers at all will cause more ware on the bearings, not so much so fast, but it will be a little quicker
however, if you could sell the wheels for better ones with proper offset and stance, lets say 20x9 +17 and 20x10.5 +15 that would be flush
Old Apr 12, 2010 | 12:53 AM
KevcoG35's Avatar
Those wheels would look great on my sedan if you want to sell them
Old Apr 12, 2010 | 01:05 AM
Xet's Avatar
Xet
wow you are going to need major spacers on those, I hope you got a really good deal on those used...
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
