Extended Studs for +0 offset
Old Apr 8, 2010 | 10:13 PM
cungkpham's Avatar
I will be running the Vorsstoen's 19x10.5 +0 and the 19x9.5+0
when I did a test fit, the studs barely poked through. I was looking at the Ichibas extended studs and they come in 35/45/50mm etc. What size extended studs should I be running?
Old Apr 9, 2010 | 02:27 PM
HXS's Avatar
HXS
that's weird... anyways you should always get at least 7 turns on your lug nuts.
see where to go from there.
Old Apr 9, 2010 | 02:37 PM
Frankieg35's Avatar
Are u running spacers??
Old Apr 9, 2010 | 02:41 PM
GreenGoblin's Avatar
The goblin resurrection
should not need new studs, post pics.
Old Apr 9, 2010 | 02:42 PM
GR6RR's Avatar
I run 0 offset with no extended..
Old Apr 9, 2010 | 02:45 PM
Frankieg35's Avatar
Yeah something doesn't sound right..
Old Apr 9, 2010 | 02:52 PM
elayman's Avatar
I'm pretty sure your offsets shouldn't change the amount of studs coming through, you should still have enough room to bolt down your lugs as long as you aren't running spacers to get that offset
Old Apr 9, 2010 | 03:32 PM
offset has nothing to do with pad height vs lug seat
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
