QUESTION ABOUT 19x9.5+17 AND 19x10.5+24 RIMS ON STRETCHED TIRES!
Old Apr 9, 2010 | 07:07 PM
drew89's Avatar
whats the best possible size of tire to due a stretched look with that fitment? if you go with a bigger tire say a 275/35/19(rear) on that wheel spec and i got the tire stretched would it looked more stretched? or if you go 245/30/19(rear) would it looked more stretched if you go smaller with the tire? thanks for the help
Old Apr 9, 2010 | 08:28 PM
CandlestickPark's Avatar
ill Sedan
Very hard to follow exactly what you are asking.
Is this for a Coupe or a Sedan? If its for a Coupe then you need to be looking at single digit or negative offsets (and be at a low ride height) if you are going to run stretched tires. No sense in running stretched tires with wheel gap and tucked wheels.
If its for a Sedan then you will need stretched tires, a very flat fender roll and negative camber to make that setup work, maybe 225/245 (unless you do a fender pull you can run a 245/275 setup like dznuts)
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
BlackGee35
Jul 31, 2015 11:04 AM
