Question about 19" Rays and spacers.
Old Apr 13, 2010 | 04:52 PM
plonka's Avatar
I'm thinking about buying the Ichiba spacers. Once the spacers are mounted, will I have to file down the factory studs or do the Rays have a hollow pocket on the back side to clear them. Much thanks!
Old Apr 13, 2010 | 05:35 PM
Xet's Avatar
Xet
Ummm I'm not sure on what you are asking exactly... The spacers have holes where the factory studs go through and you use the given screws to tighten the spacer onto the stock studs/hub. *This is all based on the idea that you are buying one with built in studs* Then you just put your wheel on the studs on the spacer like you would normally onto the stock studs.
Old Apr 13, 2010 | 07:19 PM
plonka's Avatar
I guess what I'm asking is, once the spacer is bolted to the hub, will the stock studs stick out past the spacer obstructing the wheel from being flush with the spacer?
Old Apr 13, 2010 | 07:33 PM
g35man04's Avatar
CLUB MODERATOR
the Spacers that you buy will have holes in them....you put those over the stock bolts on the hub....you then take the nuts that come with the spacers and put them on over the stock bolts that are showing through the holes on the spacer....then the spacers built in studs are used as the Lug-nuts on the OEM 19's....dont understand how that doesnt make sense......
Old Apr 13, 2010 | 08:13 PM
bjquinnIUmed's Avatar
OP I understand what you're asking. Not sure why it's so hard for others to understand. Anyway, I don't know the exact answer to your question. However, plenty of people run the ichiba v2 spacers with the OEM 19s without issue. You should have no problem with what you're worried about.
Old Apr 13, 2010 | 08:17 PM
ttrank's Avatar
Grocery getter
Not that tough.
He is concerned if the oem studs are going to still stick out too far and hit the wheel, through the spacer. Most oem wheels have pockets, the question is if they are going to be deep enough.
Old Apr 13, 2010 | 08:55 PM
Xet's Avatar
Xet
They don't stick out at all on either my HR's or ichiba/project kick (can't remember which one for sure right now)
edit: mine are 25mm btw
ATL_Red_G35's Avatar
G35 OEM will has back pockets for 20mm or less spacers with extended studs.
You won't have to worry about stock studs sticking past the spacers if you get 25mm or more.
Either way, it WILL work.
Old Apr 14, 2010 | 12:17 AM
plonka's Avatar
LOL, Thanks to all who responded and especially those who understood what i was talking about. Word!
Raiderpolo15
18 Inch
11
Jan 30, 2017 03:25 AM
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
mushu
Jul 15, 2015 03:55 PM
