Big Break Upgrade for the Sedan
Old Sep 21, 2004 | 02:46 AM
grappler012's Avatar
Does anyone know if they make any sort of upgrades on the brakes for the sedan other than a brake pad??
Old Sep 21, 2004 | 07:29 AM
cato's Avatar
SouthernComfort Moderator
Re: Big Break Upgrade for the Sedan
Stillen makes an upgrade kit.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 21, 2004 | 10:00 AM
R2 V35's Avatar
I'm not sure if you want to replace the whole kit or just the rotor. There are a lot of companies that makes BBK for the Gsedan. I currently have the StopTech front kit on my G.
Reggie
"Is simplicity best or simply the easiest"
Old Sep 22, 2004 | 02:46 AM
G35Lin's Avatar
Multi-Spoked Mod
I think i am going endless!
Ed
2003 Transport V35SKYLINE. Team Transport! www.teamtransport.org
Old Sep 22, 2004 | 09:58 AM
R2 V35's Avatar
Sorry Ed, I aint a high ROLLER like you [img]/w3timages/icons/tongue.gif[/img] hehe!
Reggie
Old Sep 22, 2004 | 10:36 AM
G35Lin's Avatar
Multi-Spoked Mod
lol lol. I am going fronts only. so SHHHHHH!!!!!
Ed
Old Sep 22, 2004 | 01:23 PM
Gsedan35's Avatar
Since the question say's Big Brake upgrade
Any big brake upgrade ment for the G or Z will fit on the sedan. It does require you to remove the rear dust sheilds It is highly unlikely that your oem wheels will allow their use however do caliper to wheel clearance requirements.
Bigger brakes for looks are one thing, actually needing them because of running out of brakes on the track is something else.
Also do not forget that the G35X does use a different front suspension then other G's and Z's. If a trip to the Infiniti parts counter reveals it uses the same rotor and caliper part numbers as the regular sedan, the whole thing is a non issue.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
jsimonk
Dec 22, 2023 03:49 PM
andresito7
Aug 1, 2015 04:53 AM
Karnicle
Jul 23, 2015 05:08 AM
