Tire Fitment Question
Old May 2, 2010 | 03:40 AM
AidanP's Avatar
Hey guys, I'm in the process of picking up a set of tires for my WORKS that should be arriving soon. The WORKS are 19x9.5 and 19x11. Originally I'd been planning to run a stretched tire setup, but it looks like I'll be doing a turbo build this summer and would rather have the extra rubber. I've looking at a set of Nitton Invo's in 255/35/19 and 305/30/19. I've heard of some members on here running the 305's, but wasn't sure if that was being done on 19x11's. Thanks for your input.
Old May 3, 2010 | 03:40 PM
idrive_MD's Avatar
What are your offsets? I ran 295/30/19 on a 19x11 with zero issue so now I am stepping up to 305/30/19's as well. Aside from the obviouse drop and alignment, the offset is going to be big determining factor if the tires should fit. More than likely they will, but giving us more info will further secure our answers and your choices!
Old May 3, 2010 | 04:53 PM
AidanP's Avatar
My WORKS are definitely more aggresive than the F14's you had. I'm running a 19x9.5 + 5 and 19x11 + 10.
Old May 4, 2010 | 12:06 AM
apro06g35's Avatar
you can prob run the 305 with that offset but your fenders are going to need a good roll and you may need to run a couple extra degrees of negative camber this also depends on your suspension setup
personally i would run a 255/30 and 295/30
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
mushu
Jul 15, 2015 03:55 PM
