Anyone running higher series in the front?
Old May 16, 2010 | 09:40 PM
HaTa's Avatar
Anyone running a 45 series in the front and a 40 series in the rear to keep their diameter the same ? I was going to run a 235-45-18 in the front and a 265-40-18 on the back.. Does that make sense to anyone else, the diameters and everything are almost identical as far as I can tell..
Old May 16, 2010 | 09:41 PM
iiiiiekoiiiii's Avatar
telling us your rim width would help a lot to see how much of the wall will be stretching...
no point of runnin staggered tires on same width rims...
Old May 16, 2010 | 09:44 PM
HaTa's Avatar
8 front 8.5 rears!
Old May 16, 2010 | 09:48 PM
HaTa's Avatar
Just seems weird to me to have a higher series in the front then the rear, even if it is to even out the diameter.. You probably wouldnt even notice the difference.
Old May 17, 2010 | 09:22 PM
Hammerhead i-Eagle Thrust's Avatar
im running 235/50-17s in the front and 255/45s in the rear..looks a little odd..probably wouldn't be as exagerated with 40 and 45
Old May 18, 2010 | 03:49 PM
saywat?'s Avatar
u do kno thats how the g35 with 18s came from the factory right? jus thought id throw it in there lol
Old May 18, 2010 | 06:18 PM
^ +1
Old May 19, 2010 | 07:26 PM
FCPImport's Avatar
Well I have the stock 17's on my 03 coupe and want to go to a 235 in the front. What is my best option? I've looked at 235/40 and 235/45 and going by the tire calculator on the miata website the 235/45 is probably the best option if i want to go wider. Thoughts?
Old May 19, 2010 | 09:24 PM
HXS's Avatar
HXS
a lot of supercars and exotics have larger series up front.
Old May 19, 2010 | 11:01 PM
FCPImport's Avatar
Well my two front tires are shot so I figured while I am at it I might try to go wider without being to drastic. Is the 235/45 the way to go?
Old May 19, 2010 | 11:12 PM
235/45s are too short, even 245/45s are a bit short
stock coupe with 17s has 225/50 fronts and 235/50 rears
either do what I did and get 235/50 fronts and 255/45 rears or maybe 245/45 front 255/45 rear
245/45s make wheel gap worse though...if u want a 235/45 you better get an 18 though because its like .75" too short in 17
Old May 19, 2010 | 11:31 PM
Cute. but u do know I went thru Every good lookin OEM rim possible right lol
Check the pix I posted over the years. So i know a thing or two about the tire sizes.
and now im the First 1st Gen all wheel drive on 370z 19s
19x10 +30offset 275/35/19 rear
19x9 with 245/40/19 Fronts.
OP didnt post rim width in the firstpost.
G35s came with 17s 18s 19s with different tire profiles and width. Rim width plays a good role on tire profiling. We all know that by now... I hope.
Old May 19, 2010 | 11:41 PM
you are running staggered tires with different od's on an AWD G...sounds like a good way to ruin your awd system...I hope you have done your research
Old May 20, 2010 | 05:30 PM
^^ my 8th set off staggered rims =]
Trust me Ive done enough research and ive been the genuinepig for past 3 yrs.
No problems. daily driven... AWD doesnt sense up to 0.03mm dimension difference.
Use this all the time. Learn how to use it and this will be your bibble
http://www.miata.net/garage/tirecalc.html
Old May 20, 2010 | 07:00 PM
yeah i put the sizes into tirerack and saw a larger difference, but i was probably looking at the wrong column or something
but there is a 3.5mm difference between those sizes so I'm not sure how .03mm is relivent
btw i've been using that site as my "bibble" since like 2002
