Vibration on 18" OEM rims
Old May 23, 2010 | 01:46 PM
maxpusher's Avatar
20 Year Member
Hello,
I have an 05 sedan with the 18" OEM rims. Last year, I installed 245/45/R18 Goodyear Eagle F1 GS-2 tires on the rears only.
Now, the fronts have worn so I installed new tires (same brand), and rotated the tires (new tires in rear, old tires in front). All tires have 40 psi and torqued to 85 Ft Ibs. Now, I am experiencing steering wheel vibration at 65-75 mph. I got the old tires rebalanced and it is still doing the same thing.
I was thinking it was a suspension problem so I installed the new tires up front and put the old tires in the rear to check if I notice the same problem. No steering wheel vibration is noticed and there is only slight rear vibration.
What could be with the wheel? I know it has something to do with the old tires but am stumped on the problem. I would like to hear your opinions. Thanks.
Old May 23, 2010 | 06:49 PM
avs007's Avatar
Did the place that balanced your tires use a Hunter machine?
Old May 27, 2010 | 09:48 PM
MaZeRsX's Avatar
Are you running any spacers?
Is your car lowered??
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
