Need help on changing rear brake pads...
Old Sep 27, 2004 | 12:59 AM
dklau33's Avatar
I have a sedan if that makes a difference from the coupe. How do you undo the lower 14mm caliper bolt that allows the caliper to to swing up to access the pads? The radius rod from the rear suspension unfortunately is in the way and doesn't allow much room for me to use a ratchet or breaker bar and a 14mm socket to undo the bolt. The only thing that will fit in between is a 14mm open end wrench and that is way too small to get any leverage to break the bolt. What tool do I need to break that bolt and to be able to torque it back down after changing the pads? Thanks.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
Old Sep 27, 2004 | 11:05 PM
THX723's Avatar
G Kreuzer
Re: Need help on changing rear brake pads...
I've already PM'd you. Try jacking up the suspension so the radius rod is just out of the way. You should have just enough space to sneak a socket and a short extension to the bolt.
Clint (THX723)
Old Sep 28, 2004 | 01:24 AM
dklau33's Avatar
Thanks Clint. Didn't think of using my smaller jack to raise the suspension up. I'll give that a shot and I'm sure it'll work.
kinetek
Aug 3, 2015 04:25 PM
atk08
Jul 30, 2015 03:12 PM
sahizzle110
Jul 29, 2015 11:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
emorehs
Jul 17, 2015 09:45 AM
