would it be ok?
Old May 31, 2010 | 12:11 AM
kennymo's Avatar
would it be ok?
i am going to be installing some extended studs tomorrow that are from v1 15mm spacers. i dont have the spacers just the studs. but to my understanding i should be able to run up to a 15mm spacer with those studs. anyways. i dont know what size i want to run. so my plan was to put the studs in and then use washers on the studs to push the rim out just to see how big of spacers i want to buy. problem i have is i only have enough washers to do it on 2-3 studs depending on how thick i make them. so would it be ok to just bolt the rim on and set it on the ground with only 2-3 lug nuts bolted up? i am not going to drive it like that. just test fit.
