Clearance question for the Experienced Members
Old Jun 14, 2010 | 08:03 AM
idrive_MD's Avatar
Originally Posted by vq35dedriver
^ why do u run a 285/30 up front for??
For a number reasons actually. First, I dont like stretching tires all that much. Second, 255/35/19 was getting overwhelmed by my rear grip and thirdly becuase I like seeing the impressions of all of my subaru friends because I can fit tires on my fronts that they can't fit at all.
Right now I feel like I have just the right amount of rear oversteer, it borders on neutral. Before with a 255/295 setup I was loosing the front end a lot on hard braking corners, short hairpins and such. The 285/305 combo has cured all of that.
I may have been able to get over it by adjusting my sways, but I figured tires would be the better way of doing it. with my wheels, I didnt have to do any fender work to make it fit, so it was no biggy.
Old Jun 14, 2010 | 11:20 AM
Buddi's Avatar
Originally Posted by idrive_MD
The "a" in his sentence didnt mean anything other than being used to start his sentence, its not a reference to face style. I also agree with Str8dum1, the front size is not that aggressive.
Since you asked, my setup is as follows:
Forgestar F14 wheels and Hankook Ventus Evo V12 tires
19x10+20 with 285/30/19 fronts
19x11+23 with 305/30/19 rears
LOLOL... oh man... im going nuts trying to figure out what the "a" means.. well thank you for that clarification...
Old Jun 14, 2010 | 11:22 AM
Buddi's Avatar
Originally Posted by VA 04 g35
5mm to clear the caliper...
Thnxs on the input... the less i use for clearance the less camber and tucking i would have to use.. thnx..
Old Jun 14, 2010 | 11:25 AM
Buddi's Avatar
And if i may ask.. what are you dropped on.. that your able to run those size tires ... did you do ne fender work at all.. ?
Old Jun 14, 2010 | 12:58 PM
idrive_MD's Avatar
I am dropped on Cobb Tuning 350Z springs with a rear sping mount mod to level the rear in respect to the front. I have them wrapped around Tokico D-Specs. I rolled my rear fenders and got an alignment thats a compromise between street and track, so I am a little cambered in. I rub the fender liner in the front a little, but only on hard bumps, otherwise no additional fender mods and no interference elsewhere.
Old Jun 14, 2010 | 01:34 PM
Buddi's Avatar
Umm i see... do you know the specs on the 350z Codd springs (drop height)... and were you able to use the oem camber arms.. or did you need aftermarket... reason for asking.. i have Bilstein pss10 coilovers.. which most likely...i will have to get camber arms to get into spec... im not looking for a slammed car at all hence i live in NYC.. pothole city... i was thinking of a 1 - 1 1/2 inch gap between wheel and fender ...do you have pics of your car so i can see the ride height?
Old Jun 15, 2010 | 12:22 PM
idrive_MD's Avatar
The Cobbs are low, certainly in the front. The rears required the spring mount mod to level them off, but if you want to be higher for clearance reason I suggest you just setup your Bilsteins a little higher. I am still on stock front camber arms, but I did install SPC rear camber arms and toe-bolts.
Old Jun 16, 2010 | 08:11 AM
Buddi's Avatar
umm i see.. well all i can say is thanx for the input.. this helps alot...oh by the way .. waht are your specs for your camber (f&b)... if you can remember?
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
pxlds
Jul 30, 2015 01:31 PM
Ashton35
Jul 17, 2015 10:11 AM
