Clearance question for the Experienced Members
Old Jun 3, 2010 | 05:27 PM
Buddi's Avatar
Noob here really trying to figure out if i can get a BBK setup (Akebono)... really need the help and advice from the experienced members here..
(ok my wheel specs are 19x9.5 +23mm front and 19x11.0 +15 for the rear.. I was told that the rear would clear a BBK.. and the front wouldnt (custom made to fit flush)... now... would wheel spacers help clear the BBK in the front along with a fender roll and enough camber to fit and not poke out.. (or am i wishing for too much) but if so what size spacer would you think i need? )
All are welcomed..... thanks
Old Jun 4, 2010 | 01:37 PM
Buddi's Avatar
bump... ne one?
Old Jun 5, 2010 | 11:10 AM
Buddi's Avatar
bump guys... really need some helpp..
Old Jun 9, 2010 | 05:54 PM
Buddi's Avatar
mods please close thread
Old Jun 10, 2010 | 10:47 AM
idrive_MD's Avatar
Its not so much a wheel size and offset issue as it could be a spoke design issue as well. I would think that spec wise you should be ok, but thats hard to tell until we see the face of the front wheels.
Old Jun 10, 2010 | 12:14 PM
Buddi's Avatar
ok .. well the rims are Work T1s... so im not so sure if that helps in ne way at all regarding the spoke design.. but i custom ordered them.... so i dont even have them as yet...
Old Jun 10, 2010 | 12:25 PM
idrive_MD's Avatar
have you browsed the Work T1S thread? Should be loaded with helpful pictures and content.
Old Jun 10, 2010 | 12:32 PM
Buddi's Avatar
yes i have...see my mistake was ordering custom size rims...which at first i wanted to fit flush with the fender.. so the rep from Ravspec (vendor).. came up with the offsets above... then the BBK came to mind after seeing affordable kits (akebono)... i was told since i asked for the wheel to sit flush with the fender.. that it wont clear a BBK in the front ... i just want to know if adding a spacer would make the wheel poke out to much... or it would solve the clearance issue..
Old Jun 11, 2010 | 01:09 PM
idrive_MD's Avatar
a spacer or even washers might do the trick, but that could require some additional camber to get your wheel to sit flush without too much poke like you are fearing. I would think a spacer in the 3-5mm range clear it, buts really just a guess on my part. You'd want to get some longer wheel studs too if thats what you are going to do.
Old Jun 11, 2010 | 01:33 PM
Buddi's Avatar
what specs or you from rims if you dont mind me asking.. and thank you for the info.. im hoping that that i can use the smallest spacer and not have that fear of sticking out to much .. guess i have to wait till i get the rims to confirm .. but thanx
Old Jun 11, 2010 | 02:29 PM
str8dum1's Avatar
a +23 9.5" front wheel wont fit flush, esp if you are running under a 255 tire. you have PLENTY of room to add at least a 10mm spacer.
Old Jun 11, 2010 | 03:27 PM
Buddi's Avatar
Now im not so familiar with what u mean by the "a".. i know rims have diff disc settings using the letters... and im not so sure what mines is... but if my rims r what you stated above that will be great news... i will confirm what letter it is... and get back with the info
Old Jun 12, 2010 | 10:41 PM
idrive_MD's Avatar
The "a" in his sentence didnt mean anything other than being used to start his sentence, its not a reference to face style. I also agree with Str8dum1, the front size is not that aggressive.
Since you asked, my setup is as follows:
Forgestar F14 wheels and Hankook Ventus Evo V12 tires
19x10+20 with 285/30/19 fronts
19x11+23 with 305/30/19 rears
Old Jun 13, 2010 | 02:16 AM
EL-EE-ES's Avatar
5mm to clear the caliper...
Old Jun 13, 2010 | 02:20 AM
vq35dedriver's Avatar
^ why do u run a 285/30 up front for??
