FML tire problem
Old Aug 6, 2010 | 11:52 AM
NjMatteSedan's Avatar
FML tire problem
so i bought a new tire online brand new pirelli i found for a good price. Installed on monday and the tire was rubbing hard on the fender the past few days when i hit bumps. I was gonna go for a fender roll today to correct the issue but i noticed my tire was really low on air. i filled it up with air and now it's low again. Is the tire done for? i don't see any shreds or holes
Old Aug 6, 2010 | 11:58 AM
Sen's Avatar
Sen
I had a similar problem recently. I turned out it was the valve stem. It was loose and causing air to leak out. They rebuilt the valve and it fixed it.
Old Aug 6, 2010 | 12:05 PM
I've been running it since monday and it just started happening today. I'm thinking the constant hitting on the fender caused damage. When I go for the fender roll I'm gonna see if they can inspect the tire for me. If it's unrepairable I'm gonna have my ugly stock 17 for now and have the $120 go down the drain..
Old Aug 6, 2010 | 06:04 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Best to take to an installer and have them check it out. They have all the tricks to finding leaks you normally can't see.
Old Aug 6, 2010 | 06:51 PM
yea the leak was on the thread not on the sidewall, had nothing to do with the rubbing. 4 day old tire and already having bad luck. They put a plug and is good to go now. Still gonna get a fender roll though
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
Srinidhi
Aug 7, 2015 03:38 PM
wojowojo16
Jul 27, 2015 09:57 AM
Soumilg
Jul 18, 2015 12:33 PM
