replacement of BREMBO
Old Oct 7, 2004 | 02:53 PM
bang79's Avatar
when should the brembo brake pads be replaced. I'm hearing different answers and was wondering if anyone knew.
Thanks
Tony
Old Oct 8, 2004 | 02:20 PM
nnkfws333's Avatar
Re: replacement of BREMBO
Well, isn't the rule when you start to heal squeaking its time to replace...Brembro's are just like every other brake systems just with a better caliper design and rotor combo....on my 240sx I swapped to a 300ZX 4 piston caliper setup and they stopped as good as the baer or stoptech brake systems.
S13/SR20 for sale
Old Oct 8, 2004 | 05:58 PM
Q45tech's Avatar
2mm of pad material left on backing plate is the usual minimum.
Personally 3mm would be better as you would have more protection from fluid boiling.
Frankieg35
Mar 20, 2016 09:42 PM
miata007
Aug 17, 2015 04:36 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
