Need help on which Spacers to run
Old Aug 12, 2010 | 06:08 PM
gbert15's Avatar
Just wanted to know what spacers I would need to get my wheels flushed somehow without having to fender roll(not really necessary but would like not to) or adjust the suspension!
I got MSR 089 wheels recently with 19x8.5F +40 and 19x10R +40(not sure on the offsets! Cant see the numbers on the back of the wheels but the next is +24 which I believe isnt the case)
Current tires on them are 245/35/19F and 275/35/19R
My questions now are:
1. What size spacers should I run to get the best flush to it without making any other modifications?
2. What tires should I run to get the best ride comfort?
- What brand?
- What tire size?
- Should I go with All Season Tires?
Your help is much appreciated!
Old Aug 13, 2010 | 11:56 PM
TNC 718's Avatar
Should make sure of the offsets first so people cangive you accurate suggestions.
Old Aug 14, 2010 | 08:48 AM
EL-EE-ES's Avatar
^he did post his offset
is this for a sedan or coupe?
id run at least a 25mm and at least a 20 on the rear if its for a coupe.
ichiba is a popular brand of spacer
as far as all season that up to you and where you live. do you get snow?
Old Aug 14, 2010 | 07:03 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
25mm front and 30mm rear. Roll your rear fenders if you drop it.
Old Aug 14, 2010 | 11:32 PM
gbert15's Avatar
Ohhhh! Just got 25mm all around though? Will that still come out nicely or is it just better to add 5mm spacers?
Old Aug 15, 2010 | 12:50 AM
by15vc's Avatar
^^Please don't add a 5mm spacer on top of the 25mm..wouldn't be a good idea. Either keep the 25 or sell them and get the 30. I would do at least a 30 all around since your front is a 8.5 width.
Old Aug 15, 2010 | 01:35 AM
gbert15's Avatar
No, sorry! I meant add 5mm to the 25mm and not physically just put a 5mm on top of the 25mm spacer! Hehe!
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
cbax
Aug 17, 2015 07:41 AM
Raven7
Aug 14, 2015 04:40 PM
