any problems if i run 255 40 19 on my rear oem 19
Old Oct 2, 2010 | 08:56 PM
gphoenix's Avatar
let me know before i buy
Old Oct 2, 2010 | 09:29 PM
herrschaft's Avatar
Depends on the size of your front tire. Use this: http://www.miata.net/garage/tirecalc.html
My speedometer is 1mph off due to my tire sizes which doesn't trip the VDC.
Old Oct 3, 2010 | 04:33 AM
Blue Dream's Avatar
I drove ttrank's car solo
I'm running 245/40/19 front and 255/40/19 rear with no problems. Can't decide if I like the fatter rear tire look, but it rides well.
Old Oct 3, 2010 | 11:40 AM
gphoenix's Avatar
i have 225 40 19 in the front
Old Oct 3, 2010 | 12:41 PM
Blue Dream's Avatar
You'd probably be better off going with a 255/35/19 in the rear if you plan on keeping the fronts at 225. A 255/40 tire is going to be almost an inch taller than the 225, but the 255/35 will be only .1" shorter than the front which would be a better match for the VDC. And your speedometer won't be off by much.
rezendvous420
May 31, 2020 01:26 PM
bTanz
Oct 15, 2015 02:31 PM
