Rim Size Offset question
A 25 offset on a 10 inch rim is not flush at all, im running a 10 inch +15 on the rear im close but not flush especially if your running any camber and a full size tire like a 275. I had to do a minor roll to run full size tires. It all depends on how flush you want your wheels and what is flush in your opinion.
the rear is 19x10+15 with a 275/35/19 a 10 inch rims actually measures 10.5 from edge to edge.
the front is 19x9+15 with a 245/35/19 and same with a 9 inch rim will measure around 9.5 from edge to edge.
the best option is to get your rims and figure out the measurement and them figure out the tire size. You front wheel will actually sit 3mm out farther than mine which means 275 with a drop you might start to rub.
The rear with actually retract 10mm, which your best bet would be to run a spacer in the back and a 275 tire, and a minor stretch in the front.
Just looked at your pics on my phone. The car looks great. I may be goin the same route, just tossed up between the gold or the black. Your not dropped very much though are you? Looks like it could use a little more drop and maybe some spacers but i love the look! nice job and thanks again for posting!
yea, ill prob do the rear spring mod at the end of the winter season myself. Dont see much point in doing it now with the snow coming up here. Spacers are gonna be a must. but the tire size and wheels look sexy as hell!
marsman328
Northern California
Aug 11, 2015 07:29 PM
