Rim Size Offset question
Old Oct 28, 2010 | 07:14 PM
DT35G's Avatar
I have OEM Rays 19's right now and am thinking about getting a set of wheels that are 18x10 all the way around with 25 offsets. How flush will they fit?
Old Oct 28, 2010 | 09:25 PM
Xet's Avatar
Xet
wizzeak. you can do spacers if you want though
Old Oct 28, 2010 | 11:29 PM
gary c's Avatar
I wouldn't do it, 18X10s on the front are just way too big and you'd need to run at least 275s to fill the rim....
Gary
Old Oct 28, 2010 | 11:31 PM
SkylineGTR2789's Avatar
lol are you getting XXR 521's ?
I have those sizes all around
20mm or 25mm spacers will make you flush n give you some poke depending on tires ..
Old Oct 29, 2010 | 04:20 AM
SantanaG92704's Avatar
25mm spacers or more! neg offset looks sick! if you have the right tires
Old Oct 29, 2010 | 08:31 AM
DT35G's Avatar
These are what i was looking at too. Not sure about running 10's in the fron though. seems so wide for front tires. How does it feel? Are you running a stretch? Looks nice on your car!
Old Oct 29, 2010 | 09:43 AM
DT35G's Avatar
any other input on these sizes? how will they handle? I take turns pretty aggressively.
Old Oct 29, 2010 | 10:15 AM
It's not too wide for the front .. some people go 9.5 in the front so whats an extra half inch ?? It turns pretty nice but it doesn't feel as easy if you are turning aggressively because of all the grip .. you get a resistance kind of a feel .. some people like it some people don't.
Old Oct 29, 2010 | 10:20 AM
DT35G's Avatar
^ thanks.... Cant decide what to do here. I was thinking about putting a stretch on the front which i would think would alleviate a little of the width that actually has contact with the ground? yes? no?
Old Oct 29, 2010 | 10:28 AM
Correct .. I'm running 245's on mine .. 275 is the max that would fit .. 245 isn't a huge stretch .. its pretty mild
Old Oct 29, 2010 | 10:40 AM
DT35G's Avatar
Okay, thats what i thought. I have a 245 on my oem rays in the rear. so i guess it would be like putting my rears on the front. what series would you run on an 18", 40 or 45? Im on Tein S Techs
Old Oct 29, 2010 | 10:44 AM
45 will look thick .. 40 will look like my front .. but if you choose to do 35 I would go with 255 width
Old Oct 29, 2010 | 10:46 AM
Xet's Avatar
Xet
I wouldn't worry about the width, plenty of people running 9.5" or larger in the fronts, I am running 9.5" although it's running a 235 hahah
Old Oct 29, 2010 | 10:54 AM
DT35G's Avatar
I live upstate NY so im thinking at least a 40 because of potholes and ****.
The width concerened me because i like to take turns hard so i was wondering about rubbing issues
Old Oct 29, 2010 | 11:04 AM
I'm dropped on Cobb Z springs but ill post another pic of the fitment up front .. I don't rub .. but if you have a brembo brake or a bbk.. don't get the 18x10 all around .. get the staggered set up or spacers
