Fitment Question Work wheels, G35 to G37
Old Nov 3, 2010 | 11:21 PM
John6mt's Avatar
My buddy wants to buy my Work T1s. He has a g37 with the oem sport big brakes. My offsets on the T1s is 20x9.5 + 15 Front and 20x11 + 25 rear. We fit the rear on with no prob but the front wasnt able to go on because of the caliper. Can he run spacers to make them fit? If so how much of a spacer does he need?
Old Nov 3, 2010 | 11:44 PM
Frankieg35's Avatar
Yeah u can run a spacers on the front.. the size u need depends how much space u need..
Old Nov 3, 2010 | 11:55 PM
GreenGoblin's Avatar
The goblin resurrection
Depends on what disk you have. It should be on the front sticker.
Old Nov 4, 2010 | 12:02 AM
John6mt's Avatar
Does anybody have an estimate on how much of a spacer he needs? I'm not sure how to go about measuring it. I believe it's a J disk?
Old Nov 4, 2010 | 01:58 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
If you have A disc, you'll need at least 15mm. If it is an O disc, it will be either a 25mm or 30mm spacer.
Check the back of your wheels tho, to make sure a V2 spacer will work. Or else you'll end up with my problem. See below thread.
https://g35driver.com/forums/wheels-...cer-users.html
Old Nov 4, 2010 | 07:15 AM
Judono's Avatar
20x9.5 +15 wheel on a G37 is pretty agressive. Probably going to have to stretch a 235/30 or 225/35. Now let's say you throw on some spacers, well then you would be at what +0 or in the negs. That is some serious camber to make it fit. Only guys I have seen run those offsets with a G37 are on bags. This setup will look hella sick if you can make it work. Post some pics when all is said and done.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
kinetek
Aug 3, 2015 04:25 PM
Soumilg
Jul 18, 2015 12:33 PM
