DO 20's slow your car down?
Old Dec 9, 2010 | 03:42 PM
spacecitygroove's Avatar
Im getting rid of my aftermarket 20in wheels for some factory 18's.
Will I see a dramatic increase in performance due to some weight loss??
Ive had the 20's since day one.
Never driven a G with factory wheel.
Sorry if this is a dumb question
Old Dec 9, 2010 | 03:50 PM
JBF's Avatar
JBF
not a dramatic increase...
Old Dec 9, 2010 | 03:52 PM
Old Dec 9, 2010 | 03:56 PM
Jairen's Avatar
Yes it does. Rotaional Inertia. Take a weight, tie it to a string and try to spin it around in the air. The heavier the weight, the harder it is to spin.
It's proven to bring down WHP. If you care about HP, then I would use lightweight wheels. If you can barely drive over speed bumps or pebbles on the road, it shouldn't matter.
Old Dec 9, 2010 | 04:03 PM
anyone know how much weight im shedding?
Old Dec 9, 2010 | 04:08 PM
bjquinnIUmed's Avatar
It all depends on the wheel, but if you're riding around on a cheap set of 20's, odds are they're heavy. You may lose upwards of 10lbs per wheel, and YES, it should make a noticable difference in acceleration and braking capability.
Old Dec 9, 2010 | 04:11 PM
Jeff92se's Avatar
Red Card Crew
If it's the weight on the outside of the diameter you are worried about, then we should be discussing TIRE weight, not wheel weight
Old Dec 9, 2010 | 05:16 PM
SedanFan's Avatar
Yes however a larger diameter wheel has most of its mass towards the outside diameter of the tire. So they go hand and hand.
Old Dec 9, 2010 | 05:30 PM
Jeff92se's Avatar
Red Card Crew
Most whee/tire packages have their mass toward the outside. Whether it's the wheel or tire.
Old Dec 9, 2010 | 05:54 PM
gary c's Avatar
Yes they do, but they cause other issues too like more stopping distance and extreme wear on the entire suspension....
Gary
Old Dec 9, 2010 | 05:59 PM
Jeff92se's Avatar
Red Card Crew
Why would they if the tire/wheel package is lighter than what it's replacing?
Not that difficult for let's say a forged 20" Volk on Michelin sport pilots vs OEM G37 19s on Bridgestone RE050 run flats.
Old Dec 9, 2010 | 06:02 PM
superchargedg's Avatar
Thank you for getting rid of those rims.
Old Dec 9, 2010 | 07:00 PM
04G35NYC's Avatar
Yes it does, i had 20s before ( heavy wheels) i felt like i was driving a Civic.
Old Dec 9, 2010 | 07:02 PM
the evil i's Avatar
IMO whether you get the performance increase or not you need to take those rims off ASAP
Old Dec 9, 2010 | 07:09 PM
GR6RR's Avatar
with those pics you have posted up there, you will notice a drastic change! hahaha...
