Noobie help: Wheel fitment
ill Sedan
ill Sedan
So with a 8.5/9.5 setup and rolled fenders with those tire sizes a semi flush setup would be +25 front / +35 rear (maybe +30 depending on your camber settings). So a 20mm spacer up front and a 10mm spacer out back.
Do you know if you have a camber kit installed in the rear (or the front too), this will help you dial things in. Are you planning to stay at that ride height?
I drove ttrank's car solo
Received 1,486 Likes
on
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
08-25-2016 07:14 PM
joedaddy1
07-28-2015 02:58 PM
RAVSPEC
Wheels & Tires-Vendor
07-16-2015 01:58 AM
