Tire pressure
Old Dec 13, 2010 | 03:03 AM
Xx2006GCOUPExX's Avatar
Exclamation Tire pressure
Hey, got my winters on a couple weeks back driving nice and smooth and the other night after a highway drive the tire pressure light came on flashing then stayed on since.... keep in mind these are 17in steelie winters. any reason why, i thought the sensors were in stock 19's or does the light just need to be reset. what tp you run your winters on ?
Old Dec 13, 2010 | 08:42 AM
Kuneff's Avatar
OK, if the TPMS are still in the 19's and not in the steelies then thats your problem.. If you took the TPMS out of the 19's and put them in the Steelies then they must not be in the right position. The LF needs to be in the LF and RF in the RF and so forth...
If you did change over the TPMS and they are mixed up, just got to your closest Nissan or INfiniti dealer and get them to reset your sensors to their current location. As they sit now, your light will NOT work for low tire pressure.
Old Dec 13, 2010 | 06:45 PM
tp
Hey I never changed the sensors from the stock rims to the steelies. . Why would the light even come on?
Old Dec 13, 2010 | 07:15 PM
Shakuya88's Avatar
The light comes on for low tire pressure and system malfunction. It isn't reading any sensors, so that's a malfunction...hence light on
Old Dec 14, 2010 | 12:13 AM
ok just kinda weird I would be driving for 2 weeks before it came on thanks for the info
jsimonk
Dec 22, 2023 03:49 PM
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
