Wheel and suspention question
Old Dec 20, 2010 | 10:45 AM
geoffkiefs's Avatar
Im looking to buy some staggered 20's. 20x8.5F 20.10R with rear offset 42, Would that rub?
Looking to lower with coupe H tech's as well would I need a camber kit?
Thank you
Old Dec 20, 2010 | 01:18 PM
SDGenius's Avatar
depends on tires and camber, but you can def make those specs work
Old Dec 20, 2010 | 01:28 PM
geoffkiefs's Avatar
245/35-20 and 275/30-20, Those are the tire sizes
Old Dec 20, 2010 | 01:32 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You'll need a mild fender roll in the rear with that setup.
Old Dec 20, 2010 | 01:56 PM
geoffkiefs's Avatar
What about with coupe H tech springs would I need a camber kit for that drop?
Old Dec 20, 2010 | 03:23 PM
To get back into factory sedan specs, yes. To be in factory coupe specs, no, you won't need a camber kit. You'll still be under -1.8 degrees all around after the drop.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
