Tires
Old Dec 22, 2010 | 04:14 PM
tneal15's Avatar
Tires
I have not gotten a consistent answer if I can run 235/50-17 all around on my 2007 G35 coupe. Obviously I want the benefit of tire rotation to have them last longer. The guys at the Infiniti dealer said I could run the same size (235/50-17) all around, but when I asked the guys at Discount Tire they said no. From what you guys have seen would I have an issue running the same size all around? I have about another oil change left on the current tires.
Thanks,
Neal
Old Dec 22, 2010 | 09:12 PM
brandon1978's Avatar
The tires will fit. With different wheel widths front to rear, the tires will have to be removed from the wheels to rotate them.
Old Dec 22, 2010 | 09:14 PM
tneal15's Avatar
ok thanks! would I have an issue with the cars computer since the size would be larger in the front?
Old Dec 22, 2010 | 09:18 PM
the_sedan's Avatar
the coupe 17s are wider in the rear. if you ran that same size all around, the fronts will look a lil bigger than the rears but not much.
Old Dec 23, 2010 | 11:10 AM
Irrelevant's Avatar
I've been running 225/55-17 snow tires all the way around without issue. You shouldn't have any issues.
This might help you out a little. Keep your tire diameters within 3% of the factory tire size and you shouldn't have VDC issues.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
