rim fitment question
Old Dec 30, 2010 | 11:46 AM
M@rCo's Avatar
Need help from all the fitment gurus out there lol. (already searched)
F- 19x9.5 +17 offset R- 19x10.5 +18
if i run a stretched tire lower on coils, and run negative camber will these fit (fenders are pulled)
Old Dec 30, 2010 | 12:01 PM
FlyingLumpia's Avatar
dont forget to lower your car about 3 inches or more.
Old Dec 30, 2010 | 12:08 PM
M@rCo's Avatar
true..getting form and fucntion coils though so that wont be a problem. otherwise you think they'll fit?
Old Dec 30, 2010 | 12:14 PM
CandlestickPark's Avatar
ill Sedan
Yes they will fit. Like Ernie said you need to be lowered 3"+ for this to look proper.
Vivek used to have a setup similar to those specs with his SF Winnings.
19 x 9.5 +17, 225/35
19 x 10.5 +19, 235/35
You could still fit these with a 245 out back with enough camber and depending on how large your pull is.
Old Dec 30, 2010 | 12:17 PM
M@rCo's Avatar
thanks marcus...was looking for a pic of it pulled off. the setup im looking at has a front 245/35/19 and Rear 275/35/19..so possibly I could use the 245 on the rear since my pull is pretty big (ill post a pic of it later) or just try to buy the rims without the tires.
Old Dec 30, 2010 | 12:22 PM
Hotdawwgman's Avatar
God I love that color
Old Dec 30, 2010 | 12:31 PM
ill Sedan
No prob. Yes, move the front tires to the rears and get 225/35s up front. You'll need to run a spacer up front, a 5 or 10mm depending on your pull.
If the 275s have a lot of tread left try and buy the wheels without tires that way you aren't paying for tires you won't use.
Old Dec 30, 2010 | 02:08 PM
M@rCo's Avatar
No pull or roll up front..prob shlda done that before painting the whole car =/
Old Dec 30, 2010 | 02:22 PM
ill Sedan
You should at the very least remove the 2 screws in your fender liner and pinch your fronts flat using a fender finisher (in that order otherwise an impression of the screw will show up in your fender if you pinch them first).
Old Dec 30, 2010 | 07:34 PM
toymachine2009's Avatar
just wondering how do shops pull a fender? does it require repaint? or Can they do that without chipping and damaging paint.. I know I got my rear fenders rolled and no problems with paint or anything just wondering if thats the same for a pull?
Old Dec 31, 2010 | 12:26 AM
M@rCo's Avatar
theres a few different methods floating around on here...the way we did it was a pain in the *** and destroyed the paint but it was getting painted anyways so i didnt care lol
Old Dec 31, 2010 | 02:17 AM
That's cool.... I love the paint job
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
EasySausage
Jul 14, 2015 11:17 PM
