TPMS light flashing, right after dealer reprogram! 350z wheels!
So I put the 350z Anniversary wheels and new sensors on about a month ago. Took it to the dealer today to have the sensors programmed, light was off when I picked it up. Then 5 miles down the highway, **** starts flashing again and stays lit! Anyone else have this issue with these wheels? Sensors came working from another G37 and weren't damaging during mounting. The weird thing is, when I first put the wheels on, it took like 2 days for the light to even come on. Now when I start the car, the light flashes for like 40 seconds and stays solid, which is what it was doing before the reprogram.
Also, I'm sure the sensors are working because when I first left the dealer, the light came on. Pulled over to a gas station to check the pressure. Stupid tech left the right rear tire at 24psi. When I set the pressure, the light went out instantly. Then came back on flashing 5 miles later!
Here's a vid!
Here's a vid!
Well, they claimed the right rear sensor wasn't installed properly and was leaking. I put these wheels on in November and never touched the air pressure since. Point being, if it lost 10psi in a matter of a couple of hours, it definitely should have gone flat between November and yesterday!:jerkit:
Anyway, it's fixed so far! So I'm happy!
Luisgalvan33
Jul 19, 2018 08:16 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
